Fuses? Help!
Old Feb 7, 2012 | 01:01 PM
Mikepro76's Avatar
Mikepro76
Default Fuses? Help!
I try to start my car weekly even though I am not really driving it during the winter months. I noticed my tires were low so I got my DC powered air pump and plugged it into the cigarette lighter. It turned on for a few seconds then shut off. I figured I just blew a fuse. When I got back in the car I noticed my interior lights were not working and the lights on my heater were not lit up. Radio was still on. I did not have time to pop open the fuse panel today. Does anyone with more knowledge than me know if these are on the same fuse or is it a more serious problem? Any help greatly appreciated.
Old Feb 7, 2012 | 01:13 PM
383vett's Avatar
383vett
Most likely the courtesy fuse on the upper left area of the fusebox. It protects the interior light and cigarette lighter circuits I believe.
Old Feb 7, 2012 | 01:26 PM
markKlein's Avatar
markKlein
I wouldn't start your car unless you are going to drive it, or let it idle long enough for the oil to come up to temperature. Better (IMHO) to just hook it up to a trickle charger.
Old Feb 7, 2012 | 01:55 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Try these guys; works great !
Old Feb 7, 2012 | 04:56 PM
Mikepro76's Avatar
Mikepro76
I usually let it run for 15 to 20 mins.
Old Feb 8, 2012 | 06:02 PM
bac22's Avatar
bac22
Once a month is fine for starting up, but you should run it at 2K RPM to help burn off condensation in exhaust and oil (as if you were driving on the road). Oil temps should get up to the temps you would normally see running on the road. Leave the hood open as well so that heat can dissipate since the car isn't moving. Also good idea to run A/C unit too using defrost and heat on high to help evaporate any moisture on the inside as well as lubricate internal A/C parts. Battery you should just disconnect, not necessary to use a trickle charge, but disconnecting will mean you'll lose memory in your radio.
Old Feb 9, 2012 | 08:36 AM
markKlein's Avatar
markKlein
Even a disconnected battery will discharge and sulfate. Plus, if left in an unheated area, it can actually freeze and burst over the winter.
Old Feb 10, 2012 | 07:56 AM
bac22's Avatar
bac22
True, but at a much slower rate then connected up...even though we're only talking 30mA.
Been on this forum a long time and never once have I seen someone complain about a battery freezing and bursting! Modern car batteries are filled with a "gel" and unless you're in continuous -20 degree weather for a month straight and the battery completely discharges, that's not going to be a concern.
Old Feb 10, 2012 | 12:32 PM
markKlein's Avatar
markKlein
I don't want to take any bigger chance than I have to of sulfating (sulfating?), of course that is a bigger concern for C5s than C4s. I also think it is better to keep all of the electronics supplied with power, but I don't have any evidence of that, I guess it is just a preference.
I have seen batteries freeze and burst, but now that i think about it, not for a long time now. I thought it was because I was careful to keep them charged up now, but maybe it is because they make them better. Back in the "day", it seems like a few days below zero was enough to freeze one, at least if it had been sitting for a while already.
To Fuses? Help!
