radio problem
Old Feb 10, 2012 | 09:24 AM
DHobbs's Avatar
DHobbs
Default radio problem
So I have a Jensen 7" DVD player in my car and for some reason it is extremely loud. When its on 1 its loud. When its on 10 its way too loud. 1 is so loud you need to yell to talk over it. What's wrong here?
Old Feb 10, 2012 | 09:53 AM
oldalaskaman's Avatar
oldalaskaman
your aftermarket stereo was interfaced with your bose speakers that also have their own amp.
Old Feb 10, 2012 | 04:43 PM
DHobbs's Avatar
DHobbs
So how do I go about fixing this?
Old Feb 11, 2012 | 11:04 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Disconnect the orange wire at the Bose speakers or replace the stock bose speakers. I am not sure where it is at, but there is supposed to be a relay for the amps somewhere. Removing it should work as well. I believe the speakers are only 1 ohm though and will most likley damage your new head unit in time.
Old Feb 12, 2012 | 05:58 PM
DHobbs's Avatar
DHobbs
Haha. Would it be easy to turn the amp off or maybe take it off of my Jensen?
Old Feb 12, 2012 | 06:04 PM
87FIREREDRAGTOP
There are acutaly 4 amps. One in each speaker assy. To disconnect the power to the amps, access each and disconnect the orange power wire. I would disconnect them by pulling the connector out at the speaker side of the plug, that way the hot wire dosen't short on anything.
Old Feb 12, 2012 | 06:40 PM
DHobbs's Avatar
DHobbs
Roger that. Then cap it off and should be good? I appreciate the help!
Old Feb 12, 2012 | 07:28 PM
oldalaskaman
if your bose amps are good take it off your stereo
To radio problem
