Odd Front Wheel bearing issue....
Old Feb 12, 2012 | 04:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Default Odd Front Wheel bearing issue....
A while back, I tested (shook) the front wheels on my '92 to check the ball joints, tie rods, wheel bearings, etc. Car has 150k.
The left wheel bearing had play so I bought a new one from a forum member. Last night, I was putting new tires on and figured I might as well change the bearing/hub...so I did. With the new hub in place, I bolted the rotor on to check it and...it's still loose. About identical to the old one! The right side one has zero discernable play. Left one, although brand new has decided loosness. With the wheel/tire on, I can shake it on the vertical plane enough to visually see about 3/16" movement of the top of the tire relative to the upper ball joint.
Is it possible that I got a bad new bearing? Or am I over looking something? Kind of annoying, but on the plus side, the new tires turned it into a NEW CAR. Steering is awesome now.
Old Feb 12, 2012 | 04:31 PM
ex-x-fire's Avatar
ex-x-fire
When you are checking the front end do you have a jack under the lower control arm. Those are load bearing BJs. Sometimes it hard to see where the play is at if your shaking it by yourself.
I woundn't put a bearing on if it was loose, but I've seen a number of GM cars w/ alittle play in the wheel bearings & no noise.
Old Feb 12, 2012 | 05:27 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I did it both ways; one with the wheel hanging from the shock and the other with a jack stand under the lower arm. Same play both times. Neither bearing made noise, but both seem to have about the same amount of play. Again, passengers side...no play.
Old Feb 13, 2012 | 10:30 AM
96GS#007's Avatar
96GS#007
When the tire is grasped at 12 & 6, there should be no wheel bearing play. If there is, the bearing is worn. 3/16" is a LOT.
Old Feb 13, 2012 | 05:21 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I thought is was a lot too. MY "spec" on a unit hub has always been zero play. How lame if this thing is junk.
Old Feb 14, 2012 | 11:46 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
If you end up having to purchase another one consider forum vendor Corvette Recycling. They still have a number of front NOS units in the original GM boxes at a good price. I've purchased both front and rear ones from them over the past several years and been very happy with them. I do NOT race my car however.
Old Feb 15, 2012 | 11:08 AM
engle1147's Avatar
engle1147
It is always possible that bearing number two is a POS as well.
I know you said you checked it already - but recheck the lower ball joint on the side with the "looseness" issue....you really really need to look closely for where the "slop" actually is when you (bump/shake) check it.
To Odd Front Wheel bearing issue....
