can anyone??
Old Feb 16, 2012 | 08:23 AM
Touchton94LT1's Avatar
Touchton94LT1
Default can anyone??
Can anyone tell me what this is? I am very limited on what I know about under the hood with cars,more of an electronics guy. But i'm doing this from my phone So im not sure if I did the link right.
https://www.youtube.com/watch?v=BFpe5jsN8Sg&feature=youtube_gdat a_player
Old Feb 16, 2012 | 08:30 AM
cv67's Avatar
cv67
St. Jude Donor '05
Sounds like starter to me?
How fresh is the battery? Cables all tight?
Old Feb 16, 2012 | 08:40 AM
1963SS's Avatar
1963SS
Sounds like the starter solenoid clicking. Many times the starter is bad but it may be loose battery or starter cables.
Old Feb 16, 2012 | 08:47 AM
red89c4's Avatar
red89c4
another one for starter/solenoid
Old Feb 16, 2012 | 08:57 AM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
Sounds like a pretty solid knock, more than just the solenoid. Almost like the bendix is hitting the flex plate instead of engaging and allowing the starter to turn.
Can you get a socket on the front of the crank and give it a little movement in either direction and try to start it again?
Old Feb 16, 2012 | 08:59 AM
Touchton94LT1
I was thinking starter as well, I removed battery and cleaned terminals still the same.
Old Feb 16, 2012 | 09:01 AM
Touchton94LT1
Im not sure what im looking for :| I know im horrible
Old Feb 16, 2012 | 09:03 AM
cadwiz_01Z's Avatar
cadwiz_01Z
Maybe just try to turn the engine by using the serp. belt. You shouldn't have to move it very far, just enough to let the starter engage.
Old Feb 16, 2012 | 09:08 AM
Touchton94LT1
Ok I turned it until I heard a click, hesitation on first key turn then it started right up
Old Feb 16, 2012 | 09:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
Charge your battery up real good then try it
If it keeps doing it replace the starter.
Disconnect the battery first when you do it.
2 bolts it drops down. There are some wires attached so dont let it rip them out. Easy repair
Old Feb 16, 2012 | 09:13 AM
cadwiz_01Z's Avatar
cadwiz_01Z
That could mean a few things:
damaged flex plate outer ring gear
damaged starter drive gear
damaged bendix
solenoid getting ready to go down for the count
Does this happen often? Does the starter grind at times?
Old Feb 16, 2012 | 09:14 AM
Touchton94LT1
This is gonna sound bad but idk if im even looking at the starter >.<
Old Feb 16, 2012 | 09:15 AM
cv67's Avatar
cv67
St. Jude Donor '05
Starter under the motor passenger side. Behind the exhaust manifold.
Maybe someone has a diagram or photo of theirs, dont have a vette.
Old Feb 16, 2012 | 09:21 AM
Touchton94LT1
damaged bendix
It just started few days ago, went to crank it and click, this is my DD as it gets better mpg then my Tahoe
Old Feb 16, 2012 | 09:35 AM
cadwiz_01Z's Avatar
cadwiz_01Z
At least you know that you can get it to start if you have to, but probably gonna need a starter/solenoid replacement. Got any mechanically inclined friends that will work for beer?
Old Feb 16, 2012 | 09:41 AM
Touchton94LT1
Any that's recommended? And I have a local Garage that's been doing work on my Families vehicles for 30 plus years. I will take it to them, I get great deals last time I had my tires rotated and balanced it was free of charge
Old Feb 16, 2012 | 09:53 AM
cadwiz_01Z's Avatar
cadwiz_01Z
If you are happy enough with them working on your car, I would let them select the starter.
Old Feb 16, 2012 | 10:34 AM
Touchton94LT1
Thanks for the feedback guys! The vette is on the shelf, hopefully on the road again soon!
Old Feb 16, 2012 | 11:11 AM
Hooked on Vettes's Avatar
Hooked on Vettes
A very common problem with the Nippondenso starter
are the 2 copper battery lugs and the copper disc
on the solenoid plunger pit and make poor contact.
You can purchase them for around $20.00 on Ebay Motors.
Search for 94 Corvette starter solenoid.
Here's a video describing the repair.
http://www.nationsautoelectric.com/densoparts.html
To can anyone??
