Headlight probs
Old Feb 16, 2012 | 10:47 PM
Pangit11's Avatar
Pangit11
Default Headlight probs
ok My 84 Vette is running excellant but my right headlight flutters when its connected,got another one from car place and it does same thing,where do i start,probalby a short but from where,appreciate any help at all thanks
Old Feb 16, 2012 | 11:30 PM
derekguzz's Avatar
derekguzz
there should be a ground close by right off the wiring, check there, make sure connection is tight on the harness ect. I had a battery going bad years ago and my lights flickered ect once in a while. The back of the bulb there is a connector that may have dirt in it or be loose.
Old Feb 17, 2012 | 02:36 AM
oldalaskaman's Avatar
oldalaskaman
there is a ground on the frame rail, I think on both frame rails, by the ends of the radiator, check for loose
To Headlight probs
