91 brakes
Old Feb 17, 2012 | 11:38 AM
19774x4's Avatar
19774x4
Default 91 brakes
when i bleed my brakes using a power bleeder i get good fluid in all wheels but the right front bleeder. no matter what i do the fluid has bubbles in it and wont come clean. i drove the car and then bleed all brakes again and still get bubbles out of the right front. i dont see any leaks in the system. whats up? i have bled them several times and still the same
Old Feb 18, 2012 | 10:09 AM
mcm95403's Avatar
mcm95403
I bled all mine last weekend when I installed my Russel braided lines. All 4 corners will had bubbles comming through no matter how much fluid we put through it. The pedal is firm and the car stops great, but I've never had that experience in 31 years of this stuff. Curious what other here have to say.
Old Feb 18, 2012 | 02:48 PM
1986coupe's Avatar
1986coupe
Any leaks at the ABS controller?
Old Feb 18, 2012 | 03:53 PM
GKK's Avatar
GKK
The air you're seeing is from the air bleeder connection.
Everytime I use an air bleeder, bubbles are visible but, they are not comming from inside the brake lines. The air line connection is sucking air from around the bleeder screw fitting. As long as the brake pedal feels firm and stops good, you're good to go.
I installed a set of Earl's Solo Bleed bleeder screws and they're the best $20 I ever spent!...
Old Feb 19, 2012 | 12:17 AM
Cliff Harris's Avatar
Cliff Harris
I have seen this happen if you open the bleeder screw too much. It sucks air in around the threads. I only open the bleeder the minimum amount to get fluid flow (about 1/8 turn).
Old Feb 20, 2012 | 09:35 AM
19774x4's Avatar
19774x4
thanks for all the help guys
Old Feb 20, 2012 | 12:33 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I hate bleeder systems, and do not trust them. If you can get someone inside the car to pump the pedal for you while you bleed, then you know for sure if there is air left or not.
Old Feb 20, 2012 | 01:36 PM
aklim's Avatar
aklim
Never used them more than once. No thanx. Only way I do it as a "One Man Operation" is if they have one that is pressurized and screws or clips on like the cover on the reservoir does. With those, you open the bleeder screw and it pushes fluid out under pressure to the reservoir and into the lines
Old Feb 22, 2012 | 10:00 AM
19774x4's Avatar
19774x4
thanks for the help
Old Feb 22, 2012 | 10:04 AM
19774x4's Avatar
19774x4
thanks for the help
To 91 brakes
