280XFI Cam
Old Feb 17, 2012 | 09:50 PM
Vincentiroc's Avatar
Vincentiroc
Default 280XFI Cam
Anyone here using that cam in their L98 or LT1? If so, what kind of power are you making? Give engine combo please? I have a 358cu with a Miniram with Fully ported TFS heads in a 1990 IROC.
Old Feb 18, 2012 | 01:36 AM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...vs-268xfi.html
Old Feb 18, 2012 | 11:36 AM
Vincentiroc
That was a few years back. Any updated since then?
Old Feb 18, 2012 | 01:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Just about everyone on 3rd gen runs that cam no results posted from over there?
Old Feb 18, 2012 | 01:43 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
There were extensive studies performed. Due to the effects of global warming (and the associated depletion of oxygen), XFI cams have lost .000001hp.
They also determined that cams with more overlap, lift, and or duration still make more power!
Old Feb 18, 2012 | 05:35 PM
Vincentiroc
Well so far my car made with the Super Ram 392whp/407wtq. Switch to the Miniram it made 409whp/372wtq. The heads wasn't ported yet.
Old Feb 18, 2012 | 07:02 PM
GREGGPENN's Avatar
GREGGPENN
What heads wasn't ported yet? AFR 195 street Eliminators?
Which intake did you like better? The one that got you 10 more HP or the one with 25ft/lbs more torque?
Old Feb 18, 2012 | 07:20 PM
Vincentiroc
Well I have TFS heads. They were flowed @ 270cfm's. Dr J's Performance has them right now. When he gets through they should flow 295-305cfm's with a 2.05 intake valve(5/16 and more head porting).
17 more HP!
Hp peaked at 5600 with SR and the MR peaked at 6100. With 3.73's the car peak 5600 going through the lights @ 112mph and this is shifting at 5900. No track times with the MR yet but I'm quite sure with the MR it would have at least gave me 114+ at a higher shift point. The car has a T5 Trans and the 60ft was around 1.80's.
Old Feb 18, 2012 | 07:44 PM
rodj's Avatar
rodj
400 wtq /The car has a T5 Trans
I see your a gambling man
Old Feb 18, 2012 | 08:00 PM
88BlackZ-51's Avatar
88BlackZ-51
17 more HP!
what are you expected those TFS to pour to flow 295-305cfm?
did they start life as 195's?
Old Feb 18, 2012 | 08:09 PM
Vincentiroc
They started life at 258cfm. Very mild porting 268-270cfm. Professional porting will get it those numbers. Ive had these heads for 12 years now.
Old Feb 18, 2012 | 08:25 PM
88BlackZ-51
Sounds good. I bought similar heads about 6 years back.
Back to my question. What do you expect these runners to measure? I was more curious about runner size then cfm numbers.
This is what my old TFS heads flowed: 195 cc head.
.200 lift(intake/exhaust) Trickflow-138/98
.300 lift(intake/exhaust) Trickflow-190/130
.400 lift(intake/exhaust) Trickflow-230/156
.500 lift(intake/exhaust) Trickflow-253/174
.600 lift(intake/exhaust) Trickflow- 260/185
Old Feb 18, 2012 | 08:44 PM
Vincentiroc
I have no idea. All I know is that Dr. J says he can make them flow -295-305cfm's and the opening of the runner is 2.4x sq inches.
Old Feb 18, 2012 | 09:14 PM
1989TransAm's Avatar
1989TransAm
Hmmmmm, your heads are going to be very similiar to mine.
Old Feb 19, 2012 | 12:54 AM
rklessdriver's Avatar
rklessdriver
Except he's all hung up on running the 280XFI instead of spending the same $$$ on a cam that'll blow it's doors off.
I reckon them 2 page ads Comp buys in Hot Rod/Car Craft/PHR really do pay off....
Will
Old Feb 19, 2012 | 02:00 AM
krackenvette's Avatar
krackenvette
Will
Old Feb 19, 2012 | 02:07 AM
rodj's Avatar
rodj
Which is why I posted the 1st link about it
Neat (Josh ) got the figures below with a 280 cam in his 383 MR w/ M6
LE Ported TFS 195's
Finished intake port volume 205 cc
Exhaust port finished volume 76 cc
.200 @ 140 / 108
.300 @ 200 / 144
.400 @ 245 / 176
.500 @ 274 / 190
.550 @ 280
.600 @ 282 / 204
Greatest RWHP achieved: 389
Best ET: 11.98
Best MPH: 119
To 280XFI Cam
Old Feb 19, 2012 | 02:30 AM
krackenvette
I had an 280XFI cam as it was recommended to me before I knew of this and other forums with people who could guide me better.
I made 419 in a 396LT1 with AFR heads, old 195's. But on another dyno it made 405. Same temp, but different dyno same brand and both were SAE.
Tuner can make a helluva difference too.
Who would you recommend for camshafts?
Old Feb 19, 2012 | 02:49 AM
cv67's Avatar
cv67
St. Jude Donor '05
everyone has their preference cris straub straubtechnologies.com will get ot right the first time.
ud Harold is good
some guys like mike Jones. more specs you have better cam youll get.
Old Feb 19, 2012 | 02:56 AM
krackenvette
ud Harold is good
