airfoil bolt damage question
Old Feb 18, 2012 | 09:58 AM
mcm95403's Avatar
mcm95403
Default airfoil bolt damage question
I'm wondering about those people who have installed an airfoil and then later had the bolt get sucked into the engine - did you/the installer use any threadlocker/locktite? It seems like this would be the only way to do this install, but no one seems to have mentioned it in the threads I've seen.
When these first came out I worked at Speed Merchant in San Jose and we never installed one without the threadlocker and never had any problems. Of course that was a long time ago.......
Old Feb 18, 2012 | 10:27 AM
cv67's Avatar
cv67
St. Jude Donor '05
Never used threadlocker never any problems.
Sure couldnt hurt though.
Hell of a way to lose an engine from a lousy screw.
Old Feb 18, 2012 | 10:28 AM
John A. Marker's Avatar
John A. Marker
I fell into the trap and got sucked in when I first bought my 85. I didn't know about the Forum back then. And yes, I used thread locker RED to be sure that it stayed put.
My next "upgrade" back then was to install 1.5 & 1.6 roller rockers. I had heard stories about the rockers coming apart and parts going into the pan. I cleaned all the oil return holes in the heads and epoxied in fine wire mesh over all these holes.....just in case. Never had a problem, but felt safer.
Old Feb 18, 2012 | 01:38 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If it matters....Not all airfoils require a screw.
Old Feb 18, 2012 | 01:54 PM
383vett's Avatar
383vett
When my 84 was 2 years old, I installed a NOS crossfire nitrous kit. I braised anut on the end of the throttle body bolts in order to fasten the air cleaner. One of these nuts came undone, motor swallowed it and cracked a cylinder. Not the worse thing though. Since the car was no longer be original, I didn't hesitate to pop a better engine in it. The first of many.
Old Feb 18, 2012 | 04:41 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I used threadlocker on my 87 and never had a problem.
I think it said to use it in the installation instructions and I think a little tube even came with the airfoil. I don't remember for sure, but I think it was an SLP airfoil, but it has been 20 years ago.
Old Feb 20, 2012 | 10:10 AM
VETTEHIGH's Avatar
VETTEHIGH
I did 4-5 years ago. Destroyed my engine. Cost $16k....of course that was with all my customs
To airfoil bolt damage question
