low fuel pressure?
Old Feb 28, 2012 | 09:03 PM
mcm95403's Avatar
mcm95403
Default low fuel pressure?
I finally got to my fuel pressure gauge today and check the 91. The highest pressure I see is after shutoff at 41 psi. It does hold pressure steady after shutoff. While running at cruise rpm pressure is steady at 35. I didn't see it go above 37 at any point while it was running.
Sound like fuel pump time? I have a new filter but haven't changed it yet. I recall these filters being just a screen inside. Could there be so much crud in the filter that pressure is being reduced? Gawd, I sure hope not.
Old Feb 28, 2012 | 09:09 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I would change the filter and see what you get. The higher pressure while the engine is off kinda of says to me that while running, there is some blockage between the filter and the pump, and when the motor is off the pump catches up just a bit before shutting off.
Old Feb 28, 2012 | 10:07 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
FP should be higher with the engine shut off. Consider that injectors running (firing) are like a controlled leak in pressure.
Mine is 34lb/in when running. No problems with that pressure and a 383.
Old Feb 28, 2012 | 10:30 PM
bjankuski's Avatar
bjankuski
running engine vacuum reduces fuel pressure, your pressure seems fine to me. What is the pressure when you disconnect the vacuum regulator line? It should be around 43 psi when running and at WOT.
Old Feb 28, 2012 | 11:17 PM
mcm95403's Avatar
mcm95403
Not sure if I could set up this gauge to read at WOT. It's a hand-held diagnostic gauge.
To low fuel pressure?
