diy alignments?
Old Mar 6, 2012 | 11:48 AM
rithsleeper's Avatar
rithsleeper
Default diy alignments?
Anyone do their own without a rack? I've seen those leveling things that go on the rim. Not sure how those work on toe and caster adjustment.
Thinking of ways to save myself some money in the long run and maybe some friends too.
Old Mar 6, 2012 | 12:10 PM
engle1147's Avatar
engle1147
If your DIY adjustments are "off" you can kill a set of tires in just a few miles. Tires ain't cheap....and your friends may get pissed.
If you know what your doing and the car is/has settled you can get stuff super close with just a tape measure, piece of flat bar and a level (camber).......but the smart money is still to take to an alignment "shop" and let them break out the mirrors and lasers to dial it in.
When you take your car to the shop for alignment ask for before and after print outs.
Old Mar 6, 2012 | 12:45 PM
Crepitus's Avatar
Crepitus
There are some very good threads on this on the AX/Road Race board
Old Mar 6, 2012 | 01:21 PM
383vett's Avatar
383vett
I do all my alignments on all my cars at home. This way I know it's done right and done to my exact specs, not just "within specs".
Old Mar 6, 2012 | 02:59 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Soon as I get my rear end back in I'll be right over.
Old Mar 6, 2012 | 03:24 PM
RedLS1GTO's Avatar
RedLS1GTO
I use Longacre stuff... I guarantee that I am as good as any shop out there.
Old Mar 6, 2012 | 03:33 PM
rithsleeper
Another reason I ask is that only one shop can get my car on a rack. I trust this guy but it is 100 bucks for a 4 wheel, which is not outragous but still, to me that's a lot of money.
I do my sandrail with a tape measure but everything is exposed. Ill have to look up how to fab my own setup.
Old Mar 6, 2012 | 04:42 PM
383vett's Avatar
383vett
Glad to help, Kim
Old Mar 6, 2012 | 07:48 PM
oldalaskaman's Avatar
oldalaskaman
you can get a pretty good alignment doing it yourself, it takes time, there's excellent tech on here for it as already posted, theres a procedure that needs to be followed or you will eat tires. a four wheel alignment at firestone runs bout $80, so $100 isnt that far off
Old Mar 6, 2012 | 08:47 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I do all my own alignments (street and race car, and customer cars). I use pieces of angle for toe plates, and two tape measures to measure toe. I can use a flat straight edge, level and tape measure to measure camber and caster. For slip plates I have used thick stacked magazines, or two pieces of steel with grease in between. It is really simple to do once you have done it a couple times. I can now do alignments quicker and more accurate than the alignment shop.
Old Mar 6, 2012 | 09:16 PM
kimmer's Avatar
kimmer
That's cool Kubs, never thought of magazines.
Old Mar 6, 2012 | 11:11 PM
Rob31's Avatar
Rob31
I have used go tire dollies (with good urathane wheels )
other times I have used wax paper .
I use a longacher gauge , A tram guage for tow And I have a lazer level (20 bucks )to square everything up
Old Mar 6, 2012 | 11:20 PM
kimmer's Avatar
kimmer
Originally Posted by 383vett
Glad to help, Kim
I'll take you up on that Willie.
Old Mar 6, 2012 | 11:35 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The biggest challenge is to find a leveled area. In my three car garage there is one spot.
Old Mar 7, 2012 | 08:40 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Interesting.
I have set toe several times using the "string" method. I am confident that I can do that well.
I have not set caster/camber yet, but I think I am going to try it too. I haven't decided on what the best low cost equipment would be though.
Old Mar 7, 2012 | 09:03 AM
oldalaskaman
I've done them with a 2 foot level and some jack stands and string, camber and toe are pretty straight foward, caster is a bit more tricky.
Old Mar 7, 2012 | 09:30 AM
Muffin's Avatar
Muffin
Props to you guys who have the smarts and tools to do this. I will put discretion before valor here and seek a pro.
To diy alignments?
Old Mar 7, 2012 | 12:04 PM
rithsleeper
Well I feel like I get an alignment like once every year. However, maybe its just my imagination but the car seems rougher at 60 after the first 6 months. After a fresh align the car feels very planted at any speed, even over 100.
Old Mar 7, 2012 | 03:13 PM
85 500 horse's Avatar
85 500 horse
I do it the easy way. It's so simple that anyone can do it. I paid for a lifetime Firestone alignment and I get it done as often as I want for life for free. They give you a printout of all the specs so you know that it was done correctly.
Old Mar 7, 2012 | 04:45 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
My 85 has never seen an alignment machine.
Tires wear perfect so if it ain't broke I'm not fixing it
