crank pulley installation
Old Mar 10, 2012 | 06:02 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default crank pulley installation
i have an 86 vette and i cant get the vibration damper on. It lines up with the key but only goes in about 1/4 inch before it wont go in anymore. Is the key on the crank a part of the crank or should it be loose.
Old Mar 10, 2012 | 07:08 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Oops
Old Mar 10, 2012 | 07:12 PM
AGENT 86's Avatar
AGENT 86
The key is not part of the crank. Are you using an installation tool ?
I used a longer version of the stock bolt with a nut and 2 greased washers.
Thread bolt in and the use nut to drive it on.
Old Mar 10, 2012 | 09:15 PM
PMARTINEZ92126
I rented a harmonic balancer installation tool. I didnt even know they made one. it went it fine. thanks for suggestion
To crank pulley installation
