TunerPro RT Datalog
Old Mar 18, 2012 | 12:15 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Default TunerPro RT Datalog
Anyone got Tunerpro RT to datalog with a 92 or 93 Corvette?
I got it to connect with the ALDL cable, but communication connects and disconnects, with indications jumping all over.
Old Mar 21, 2012 | 01:14 PM
James93LT1's Avatar
James93LT1
Got it to work, needed the .adx file modified for the Corvette.
PM me if you need the file.
Old Apr 2, 2012 | 10:19 AM
WW7's Avatar
WW7
This also happens if you don't shut off your screen saver and sleep mode on your laptop.. Every time my screen saver would come on I would lose the connection...WW
Old Apr 8, 2012 | 07:35 PM
C4fan's Avatar
C4fan
St. Jude '10
I have never had a problem with communication with TP RT but I did with Data master. DM seemed to have blank spots or would just come and go every few seconds.
Can I ask if either of you have ever had this error on the ALDL flags? My 1 and 2 injector banks stay on 'Error' all of the time. I have Ford 30# injectors so I'm not sure if it could be affecting it either. The injector drivers 1 and 2 just below will error from time to time also.
Old Apr 8, 2012 | 08:41 PM
Caboboy's Avatar
Caboboy
How is that car coming along Bill?
Old Apr 8, 2012 | 08:51 PM
C4fan's Avatar
C4fan
St. Jude '10
Hi Tim, to be honest I took it to a local shop that has a good rep from the Vette community. I just haven't been able to get around this split BLM issue. I hoping their experience will prevail where I couldn't. Once I get that solved we can get back to the tune. Did you ever look at the last log I sent you?
Old Apr 9, 2012 | 01:13 AM
James93LT1's Avatar
James93LT1
I'm using TunerPro V5, and it look like the flags/ switches selection format is different now.
Edit.....using TunerPro RT V5.
Old Apr 9, 2012 | 09:23 AM
C4fan's Avatar
C4fan
St. Jude '10
Ahhhh, well darn. Thanks for getting back.
Old Apr 9, 2012 | 11:15 PM
Genevieve72's Avatar
Genevieve72
8th Gear
Old Nov 13, 2012 | 07:39 PM
ca-wolf's Avatar
ca-wolf
What in the .adx needs to modified for the Corvette?
Old Nov 14, 2012 | 12:25 AM
James93LT1's Avatar
James93LT1
For the 92, 93 MY, silence the CCM and ABS in the connect command.
Old Jul 28, 2020 | 11:11 AM
finn_the_flying_fox's Avatar
finn_the_flying_fox
I hate to gravedig, but being a new member to the forum, I can't send PMs. Could you send me a copy of the working .adx file? I have looked everywhere and can't find a working one anywhere.
To TunerPro RT Datalog
