What steering rack?
Old Mar 21, 2012 | 04:53 AM
ScaryFast's Avatar
ScaryFast
Default What steering rack?
I am replacing the rack in my 1993. There are plenty of brands out there, Delco, Duralast, Cardone, etc.
Anyone have a preference or one I should avoid?
Old Mar 21, 2012 | 11:19 AM
RWDsmoke's Avatar
RWDsmoke
Good luck. I replaced my Duralast rebuilt twice before I got one that didn't leak. They were covered under warranty with no problem but it was a pain to replace it each time. Don't know if others are any better. I recommend finding a local shop to rebuild your old one.
Old Mar 21, 2012 | 11:53 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Don't bother replacing it. Send it to Turn One steering.
They are the best out there, hands down. Yes, pricey, but I bet you'll only put it in once.
Old Mar 21, 2012 | 10:11 PM
DBo's Avatar
DBo
on Turn One. This is not that easy of a job if it's the first time you have done it. You only want to do it once. They do take a while to get it done, maybe a couple of weeks in my case. Dave
Old Mar 21, 2012 | 10:35 PM
dizwiz24's Avatar
dizwiz24
What symptoms do you get w/ a bad rack?
Old Mar 22, 2012 | 12:03 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Inverted nippl......never mind.
Old Mar 22, 2012 | 02:24 AM
ScaryFast's Avatar
ScaryFast
I don't have a leak or a failure, maybe I should just leave it alone. The motor's out and the rack has a LOT of miles on it, seemed like a good idea.
I've used turn one before (PS pump) but won't have time to send it for rebuild before the motor goes in.
Thanks to all for the suggestions.
Old Mar 22, 2012 | 06:50 AM
Black89Z51's Avatar
Black89Z51
You can get the rack in and out with the motor in. That's how I did mine.
Old Mar 22, 2012 | 07:50 AM
ddahlgren's Avatar
ddahlgren
If you put in a rebuild you will not know and then will have to change it with the motor in the car. If it is a 2 week turn around you could spend that much time with ones that are no good. You can help the turn around by being a bit more aggressive with shipping methods.
Dave
Old Mar 22, 2012 | 09:13 AM
dizwiz24's Avatar
dizwiz24
Lol
Old Mar 22, 2012 | 09:16 AM
dizwiz24's Avatar
dizwiz24
I ask because mine is sitting on the ground next to the car. I had to remove it to pull my ati superdamper 6+8 crank pulley.
There's nothing wrong with it, even the boots look like they are in mint shape. Now woujld be the time to fix it if anything was wrong.
I did put polyurethane bushings (2 total) in the rack since I heard positive comments on here from people who've done that
To What steering rack?
