Sway bar identification
Old Mar 21, 2012 | 11:15 AM
ddahlgren's Avatar
ddahlgren
Default Sway bar identification
How can you tell the difference from a 84-87 from a 88-96 front sway bar?
Here is a pic what does it fit?
Image: http://i37.photobucket.com/albums/e6...r28mmfront.jpg
Old Mar 21, 2012 | 02:44 PM
mcm95403's Avatar
mcm95403
I checked this last month after finding a few of the 30mm front bars at a local junkyard. The 88 and later bar is several inches wider at the end link mounting location than the early bar. Definitely won't fit. The pic you linked to should be for an early car. The lever end of the bar for the later cars has a "double jog" to it to make it wider and to clear the tires at full lock.
http://forums.corvetteforum.com/c4-g...fferences.html
Old Mar 21, 2012 | 03:48 PM
87bob's Avatar
87bob
Veteran: Coast Guard
If you need an early one I'm selling one.
Old Mar 21, 2012 | 05:15 PM
ddahlgren's Avatar
ddahlgren
Need a late one..
Old Mar 21, 2012 | 06:00 PM
mcm95403's Avatar
mcm95403
Need a late one..
They are still available new for $112:
http://forums.corvetteforum.com/c4-g...-bar-find.html
Old Mar 21, 2012 | 06:19 PM
ddahlgren's Avatar
ddahlgren
Does that fit a 91 and what GM part number?
Old Mar 21, 2012 | 08:09 PM
mcm95403's Avatar
mcm95403
AFAIK, it should fit all the 88 and later cars. It doesn't give a part number, just a description.
Old Mar 21, 2012 | 08:10 PM
mcm95403's Avatar
mcm95403
Strike that. I just tried to process an order for it to see what the shipping cost would be and got this:
These part numbers were not found in our database: 14105130. The part numbers you seek have either changed to a new part number or no longer available from GM. Please email customerservice@GmPartsDirect.com to verify the correct part numbers needed.
Discontinued.
To Sway bar identification
