fuel pump purchase
Old Mar 23, 2012 | 11:56 AM
choopes's Avatar
choopes
Default fuel pump purchase
Face with replacing my fuel pump again. (Pumps up pressure but immediately goes back to zero in about 2 sec.) What is a good, cheap source? Would you stick with A/C Delco, or is there another known good brand?
Old Mar 23, 2012 | 12:09 PM
TTOP350's Avatar
TTOP350
You need to check and make sure its a bad fuel pump checkvalve, regulator or leaking inj before you just buy a pump.
I buy my pumps from Racetronics.
Old Mar 23, 2012 | 02:33 PM
WW7's Avatar
WW7
, You should check everything above before just replacing the pump..If it is the pump Racetronics is very good, Im running there big pump for my 383 ...WW
Old Mar 23, 2012 | 04:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette?
While the pump is running clamp the pressure line near the tank; if pressure holds the pump is bad, else look elsewhere.
Old Mar 23, 2012 | 06:19 PM
choopes's Avatar
choopes
Originally Posted by 65Z01
What year Vette?
Mine is a '93 coupe.
I was reading some older post today about that. What line is it I'm to pinch off? (location, identifying it from the others?)
Old Mar 23, 2012 | 11:29 PM
gunnerjuju's Avatar
gunnerjuju
Subscribed
Old Mar 24, 2012 | 12:29 AM
Cliff Harris's Avatar
Cliff Harris
Pull off the vacuum line on the fuel pressure regulator to see if it has gasoline in it. A ruptured FPR diaphragm will have the symptoms you describe. Mine caused a fire:
To fuel pump purchase
