1984 corvette fuel pump
Old Mar 25, 2012 | 01:02 AM
84VetteMan205hp's Avatar
84VetteMan205hp
Default 1984 corvette fuel pump
how easy is it to change the fuel pump in my 84 i know its easy to take out but to replace
Old Mar 25, 2012 | 02:30 AM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...s-of-pics.html
Old Mar 25, 2012 | 10:21 AM
ffvetteman's Avatar
ffvetteman
I did one in a 88 and it was easy. You do not need to drop the tank. Pull the fuel door off and the rubber thing around the fuel neck and you can get to the whole sending unit and unbolt it. It is pretty easy.
Old Mar 25, 2012 | 10:34 AM
caddyboy84's Avatar
caddyboy84
I wouldn't use that filter you see in the pics, when it gets dirty it can collapse. I used the GM green screen type which stays open and rigid, your protected by the line filter as well. When I changed my pump, I had a simular "sock" and it was filthy and collapsing under pressure, once I changed it I had a new car again. Change the filter also.
Old Mar 25, 2012 | 11:12 AM
mtnmanut's Avatar
mtnmanut
About 30 min. 45 if you enjoy a cold beer
Old Mar 25, 2012 | 01:12 PM
caddyboy84's Avatar
caddyboy84
To 1984 corvette fuel pump
