Mat/iat
Old Mar 28, 2012 | 12:57 PM
$300vett's Avatar
$300vett
Default Mat/iat
Does the plug for the IAT/MAT on the bottom of the Plenum come from the EGR solenoid or does that plug run up to the front air duct?????????????? Thanks Bo.....
PS yes I have one plug and 2 places to put it............LOL
Old Mar 28, 2012 | 03:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
MAT sensor has about an 10" pigtail that goes between sensor and connector at main harness on firewall.
Old Mar 28, 2012 | 04:07 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by AGENT 86
MAT sensor has about an 10" pigtail that originates at main harness on firewall.
This is completely different that the separate pigtail for your IAC/TPS/MAF & AIR/ALT connectors.
Old Mar 28, 2012 | 04:55 PM
$300vett's Avatar
$300vett
Thanks.........one more for you!!!!!!!!!!!! on the bundle of wires going to the Throttle body.........there is a there is a 4 prong (IAC) valve an 3 prong (TPI) and a 2 prong......Where in the heck does the 2 prong go...........can not find it for the life of me........... also there is a sensor comming off the driver side air duct........it runs up to the drivers side fire wall and stops??????I know it should be a plug but I can not find that one either................................ Thanks Bo
Old Mar 28, 2012 | 06:10 PM
GREGGPENN's Avatar
GREGGPENN
IIRC, There is a 2-prong connector for the AIR router. If yours doesn't have the AIR pump system anymore, that's your extra plug.
Can't figure out what you mean by the other question. But the ESC and tack wires are also on the firewall.
Plus, oil pressure/sender and your MAT connection.
O2 sensor too IIRC.
To Mat/iat
