Thanks.........one more for you!!!!!!!!!!!! on the bundle of wires going to the Throttle body.........there is a there is a 4 prong (IAC) valve an 3 prong (TPI) and a 2 prong......Where in the heck does the 2 prong go...........can not find it for the life of me........... also there is a sensor comming off the driver side air duct........it runs up to the drivers side fire wall and stops??????I know it should be a plug but I can not find that one either................................ Thanks Bo
Well let me think, there is an EGR switch that mounts to the stat housing, the A/C power plug is in that bundle, then there is the temp sender, knock sensor by the front plug, I'm still thinking........
On pass side injector loom, there are connectors for AC clutch,A.I.R. Solenoids, TPS and IAC. There also maybe coolant temp sensor and/or cold start valve switch, can't remember if one or both come from drivers side injector harness.
The sensor in duct is probably the MAT sensor tha the PO moved from plenum bottom.
LOL well I think I have found it........Right up under the water hose that is connected to the throttle body.............just my luck it is broken........... Thanks Bo............
PS I will owe u a drank when this all done............Thanks again.....
you too Agent 86............
