1989 Corvette Shift Indicator
Old Apr 3, 2012 | 10:28 AM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Default 1989 Corvette Shift Indicator
I was wondering if anyone could give me a detailed tutorial on how to install a new on that I just received. What I need it the actual installation of the indicator and how to take apart the console bezel that it is under so that I can get to it. Also is this an easy task or hard?
Thank you, Stephen
Old Apr 3, 2012 | 11:10 AM
caddyboy84's Avatar
caddyboy84
Thank you, Stephen
First, take the shift **** off. If your car is auto, just pry off the button then use a snap-ring pliers to remove the **** itself (you'll see the ring when the button is off) a manual **** should just un-screw. Then just remove the screws you see, I believe the radio bezel has to come off first but you can see how the panels overlap. I recently had the interior out of my car and believe all the dash trim has to come out starting with the cluster trim, then you work your way down to the console trim. Be careful when you lift the indicator trim because the indicator light is attached. It's pretty easy once the **** is off, don't loose that snap-ring.
Old Apr 3, 2012 | 11:37 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
...and believe all the dash trim has to come out starting with the cluster trim, then you work your way down to the console trim.
You need to remove:
-tilt lever (it unscrews)
-headlight **** (small flat-blade under the slot)
-digi-dash bezel
-radio & A/C bezel
-shifter buttom, C-clip & ****
-console screws
Lift shifter console rear, disconnect shift indicator lt bulb.
Remove shifter console, replace shift indicator & lt bulb.
I don't recall if the dash pad needs to be loosened to get at screws on top of radio & A/C bezel.
When installing all the plastic use caution to properly seat all pieces and to not over tighten the screws.
Have fun with the project.
Old Apr 3, 2012 | 11:41 AM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Is there anyway around having to use snap ring pliers to get the snap ring on and off? I do not want to go out and buy them.
Old Apr 3, 2012 | 12:03 PM
caddyboy84's Avatar
caddyboy84
No dash pad and I forgot about the lever and headlight **** (Which has a clip on the back that you have to press as you pull it off). Just go to a parts store and get a cheap snap-ring pliers for about 5 bucks
Old Apr 3, 2012 | 12:15 PM
caddyboy84's Avatar
caddyboy84
One little thing I did when I replaced everything was change the screws. My plastic pieces had little cracks where the screws went and a few chips out of the plastic, so I went to the HELP section at the parts store and bought interior trim screws in black that have the black counter-sink washers on them. Everything looks mint. Another thing, if you wanna remove the shifter boot (to clean it ect.) be VERY VERY careful to NOT NOT break the studs off of the console trim piece, these things are OLD and very brittle. I broke mine off and had to remount the boot from the top with trim screws, it looks good but I'd rather not have broken it
Old Apr 3, 2012 | 12:38 PM
mako41's Avatar
mako41
If your just going to replace the orange/red shift indicator bar, and not replace the entire console bezel, you don't need to remove the shift ****. The shift indicator bar just pops into place and can be replaced by removing all the center console bezel mounting screws and lifting up the bezel while the shifter boot is still attached to the bezel and auto-stick. Just reach in under the bezel and R/R the indicator bar.
Old Apr 3, 2012 | 12:46 PM
caddyboy84's Avatar
caddyboy84
Now now......Lets not have the lad experiment with any short cuts, he'll never learn, and besides, you gotta get a snap-ring pliers eventually
Old Apr 3, 2012 | 03:30 PM
Joe C's Avatar
Joe C
, and here's a very good, and perfect size snap-ring plier for the shift **** removal. ya know what they say about using the proper tool. besides, things like this are just the excuse i need to go to the tool store!
KLINE #73242
Old Apr 3, 2012 | 03:41 PM
caddyboy84's Avatar
caddyboy84
KLINE #73242
Thats a nice cheapy I picked one up thats adjustable and you can flip the jaw around for remove & install Then again, if it's kline it's probably not that cheap.
Old Apr 3, 2012 | 04:26 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Do you think this will fit the snap ring?
Old Apr 3, 2012 | 05:17 PM
caddyboy84's Avatar
caddyboy84
Beautiful Now it's in your tool-box forever, you now have the "snap-ring plyer family", don't forget to name them
Old Apr 3, 2012 | 05:18 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Haha, will do and are those the right sizes?
Old Apr 3, 2012 | 05:22 PM
caddyboy84's Avatar
caddyboy84
YES, they should cover any sna-ring situation you'll come across.
Old Apr 3, 2012 | 05:23 PM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Good, now just gotta wait til saturday when the parts I need come in. THe indicator and Window switch. 2nd window switch in 4-5 years
Old Apr 3, 2012 | 05:26 PM
caddyboy84's Avatar
caddyboy84
Sure its the switch, try a little brass brush on the lugs and a 22cal rifle bore brush on the connector holes then use dialectric grease on the contacts
Old Apr 4, 2012 | 12:02 AM
Cliff Harris's Avatar
Cliff Harris
The snap ring is pretty deep in the **** and the holes are very small. I have a set of snap ring pliers like that and the tips are too big to fit in the holes in the snap ring. I don't think it will go down inside the shift **** far enough to reach the snap ring anyway.
I used one of these guys to get mine out (the straight one):
To 1989 Corvette Shift Indicator
Old Apr 4, 2012 | 12:56 AM
caddyboy84's Avatar
caddyboy84
You can use things like that, but you run the risk of bending that clip and once it's bent it's never right. A clip like that can snap also. Those plyers should work with no problem and that set has a small and a large pin set. I think that clip is only about an inch deep, if mine worked that set will. Don't over think things, you'll drive yourself nuts and you can never have enough tools
Old Apr 5, 2012 | 03:57 AM
Cliff Harris
I think the tips in the picture above are a little longer than the set I have. Mine has two straight tips but they're both the same size (and too large for the snap ring).
Here's what mine looks like. I replaced the spring pivot with a bolt because it wobbled around too much. I think they're Great Neck. Not sure because the printing is gone -- trans oil makes a great solvent. I saw a set at Harbor Freight that looks very close to these.
Old Apr 5, 2012 | 06:29 AM
caddyboy84's Avatar
caddyboy84
All of these are good enough, with something like a snap-ring plyer it dosen't have to be a Snap-On. I pulled my button off last night while stopped at a red light (OCD) and it's only about a half inch deep.
