keep an engine from turning / auto ??
Old Apr 8, 2012 | 12:37 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default keep an engine from turning / auto ??
Hope this isn't the dumb question of the day but I'm trying to change the opti on a 94 auto. The engine is turning as I'm trying to remove the 3 crank balancer bolts. What is the best way to keep the crank from turning? My guess is trying to hold it at the flexplate but not sure.
Thoughts?
Old Apr 8, 2012 | 12:55 PM
rklessdriver's Avatar
rklessdriver
Thoughts?
Hold it at the flex plate.
If your working alone, you can just clamp a pair of vice grips on the flex plate so it bumps up against the tranny/block.
If you've got helper, he can use a big pry bar to to hold the flex plate.
Will
Old Apr 8, 2012 | 01:24 PM
383vett's Avatar
383vett
Will
or use a flexplate tool to keep the motor from turning.
Old Apr 8, 2012 | 02:01 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
thanks. got them out.
Old Apr 9, 2012 | 12:35 PM
rickneworleansla's Avatar
rickneworleansla
A little late but here's what I did..
To keep an engine from turning / auto ??
