Life after headers....
Old Apr 4, 2012 | 01:22 PM
scottermis's Avatar
scottermis
Default Life after headers....
I ordered a set of American Racing headers with cats for my 94 and wondered what my next step should be for a little more performance. Ported air intake? Roller rockers and springs? All i have done to it so far is new plugs and wires and i added an SLP tri filter air filter system and had it tuned by lt1pcmtuning. Any suggestions would be highly appreciated!
Old Apr 4, 2012 | 02:12 PM
JackDidley's Avatar
JackDidley
If its automatic, 2800 stall converter. If its a stick, rear gears.
Old Apr 4, 2012 | 04:53 PM
scottermis's Avatar
scottermis
Any idea what is best 2800 converter to get for the c4? I have an automatic.
Old Apr 4, 2012 | 05:08 PM
JackDidley's Avatar
JackDidley
Vigilante has a good rep. Expensive though.
Old Apr 5, 2012 | 09:22 PM
nickpe's Avatar
nickpe
pete kane hooked me up.
Old Apr 7, 2012 | 07:47 AM
96 lt-4's Avatar
96 lt-4
You will notice a stall.I would recommend doing a shift improver kit(use stage one-or first stage of improvement for a street car)and an auxillary trans cooler to ward off heat.
Roller rockers and springs will give a few ponies on the top end.
Really no need for intake porting or a larger throttle body.
Replacing the stock resonator with an x-pipe will give it a few ponies and a cool sound.
Make sure your tune is spot on after any mods.
Depending on what gear you have a change to 3.45/3.54 will wake it up and also allow you to pass fewer gas pumps.
Past these you have to jump to a cam and/or heads for noticeable power.This would be the time to do springs and 1.6 rockers IMO.
An electric water pump is worth a .10 at the strip but I would save it for after a cam install when it is removed if done at all.
Old Apr 7, 2012 | 08:10 AM
WW7's Avatar
WW7
When I get a new convertor Pete K is the guy I'll get it from.....WW
Old Apr 7, 2012 | 10:00 AM
aminnich's Avatar
aminnich
What ratio on the rear end? If it is the stock 2.59 that will definitely slow down the performance.
Old Apr 7, 2012 | 10:38 AM
C4fan's Avatar
C4fan
St. Jude '10
+3 for the Pete Kane converter. Pete is a stand up guy. No worries dealing with him at all.
Old Apr 7, 2012 | 11:12 AM
IAFF alumni's Avatar
IAFF alumni
Good thread as I am in a similar place.
Car is at a local shop right now getting a complete Stainless Works install.
Long tube headers (Jet Hot coated), cat delete, x-pipe, and chambered mufflers.
Mine is also an automatic.
Motor is otherwise stock and a cruiser, not a racer.
But of course, I think we'd all like a little more performance.
I have the build sheet from the National Corvette Museum that contains all the codes.
There is a line item that states, *GM1 2.59 RATIO AX so my guess is those are my rear gears.
Can anyone confirm?
Thinking a cam swap might be down the road as well... Something a bit lumpier maybe.
scottermis, I will be interested to hear how you (and others) wake up a stock LT1.
Old Apr 8, 2012 | 11:14 AM
corvette Stu's Avatar
corvette Stu
I have a Circle D 2800, IMO it is right up there with Vigilante and a lot cheaper. Sometimes we spend over what we have to and the results are the same for us non-pro racers.
Old Apr 9, 2012 | 12:45 PM
rickneworleansla's Avatar
rickneworleansla
I also went with a Vigilante.
The right cam would also make a noticeable difference.
http://forums.corvetteforum.com/c4-t...lp-needed.html
To Life after headers....
