Temperature Switch
Old Apr 8, 2012 | 04:57 PM
Bredd1's Avatar
Bredd1
Default Temperature Switch
At what temp should the primary cooling fan come? The primary is the fan at the front of the A/C condenser, correct?
Old Apr 8, 2012 | 07:52 PM
caddyboy84's Avatar
caddyboy84
Yes, and it should be cotrolled by the temp switch by the #1 plug.
Old Apr 8, 2012 | 08:01 PM
Bredd1's Avatar
Bredd1
At what temp should this fan come on? There are conflicting ideas about which fan is primary. Some say the smaller fan that pushes air toward the radiator is the primary, others say that the big fan that pulls air through the radiator is primary, which is correct? I would think the primary would cycle on first and the secondary would come on at a higher temp if needed.
Old Apr 8, 2012 | 08:12 PM
caddyboy84's Avatar
caddyboy84
The primary is the smaller fan, the secondary is the large fan behind the radiator. The secondary is controlled by the switch on the pass side and controlled to go on at 228 degrees or when the A/C is turned on, the primary fan is controlled by the switch by #1 plug. If you wanna know the temp, pull the switch and the temp should be stamped on the sender. You'll lose some coolant though.
Old Apr 8, 2012 | 08:20 PM
WW7's Avatar
WW7
The primary is the larger fan that comes on first at 228..The smaller fan in front of the radiator is the secondary that comes on at 238.....(Primary- First)....(Secondary- Second)......Some C4s like mine don't even have a secondary fan.....WW
Old Apr 8, 2012 | 08:28 PM
caddyboy84's Avatar
caddyboy84
The primary is the larger fan that comes on first at 228..The smaller fan in front of the radiator is the secondary that comes on at 238.....(Primary- First)....(Secondary- Second).......WW
Thats the first I'm hearing of that, everything I've seen ,done and read says the oppisite. My small fan comes on first and my large fan NEVER comes on because my car never gets that hot, I guess I'm wrong. Wouldn't be the first time.
Old Apr 8, 2012 | 08:51 PM
WW7's Avatar
WW7
Below is a second opinion incase you don't believe it...If your small fan is coming on first, someone wired it to do that because the large fan is suppose to come on first , the small fan is suppose to come on as a backup incase the primary is having problems keeping the engine cool. On most early C4s the small fan was an option that had to be ordered..WW
Originally Posted by TheCorvetteKid
The primary fan is the one BEHIND the radiator (towards the engine). The secondary fan is mounted ahead of the radiator and only comes on at VERY high temps.
Hope that helps.
Old Apr 8, 2012 | 08:59 PM
caddyboy84's Avatar
caddyboy84
So based on this information, our cars should be running at about 230 degrees? I'll be the first to admit I'm wrong, but based on all I've been told and how I set my car up, it appeared to me to be the way it was. I haven't heard of anyone having thier car run those temps. So I'll revise my answer to "I suggest doing it this way". Would I be correct in saying that?
Old Apr 8, 2012 | 09:24 PM
WW7's Avatar
WW7
Our cars aren't suppose to run at a constant 228 or 238 degrees, but in a situation like heavy traffic they can get this high. The secondary fan is a backup incase the primary can't hold the temperture low enough (228). The temps that these cars run is all over the place because of different levels of maintainence through the years and different mods done to them. My 89 with a 383 engine for instance, never gets over 196 degrees even in stop and go traffic because of the mods I have done, which include a Dewitte's radiator , a high speed fan , and resetting my fans to come on at 195 degrees and off at 184..Most stock early C4s usually run around 190 -210 highway depending on the level of maintainence they have had and the region they are being used in...WW
Old Apr 8, 2012 | 09:31 PM
caddyboy84's Avatar
caddyboy84
Our cars aren't suppose to run at a constant 228 or 238 degrees, but in a situation like heavy traffic the can get this high. The secondary fan is a backup incase the primary can't hold the temperture low enough (228). The temps that these cars run is all over the place because of different levels of maintainecne through the years and different mods done to them. My 89 with a 383 engine never gets over 196 degrees even in stop and go traffic because of the mods I have done, which include a Dewitte's radiator , a high speed fan , and resetting my fans to come on at 195 degrees and off at 184..Most stock early C4s usually run around 190 -215 depending on the level of maintainence they have had and the region they are being used in...WW
I understand I really need you to set me straight here on something, I've been told that the temp switch on the rear pass side head controls the large fan (Primary, I now know) and is controlled by the ECM. Heres the question; Is that true or is that just a basic temp switch that I can change to trip the large fan on at whatever that switches temp is that I choose?
Old Apr 8, 2012 | 09:34 PM
Bredd1's Avatar
Bredd1
Thanks for clearing that up. I thought the smaller fan should have been secondary. The 228 temp seems high even though everyone I talked with say it normal for the engine to get this hot. Mines usually runs around 220-228 depending on weather. I'd like to see it lower, what can I do? I changed the thermostat to a 160* today, what else will help?
Old Apr 8, 2012 | 09:37 PM
jfb's Avatar
jfb
The primary fan comes on at 228 F and the secondary fan comes on at 238 F. GM says to turn off the engine if the coolant temp reaches 260 F and let the engine cool down . They say this because 50% antifreeze at 15 psi boils at 265 F and the heads have the highest temp and boiling coolant cannot transfer much heat and the heads/valves could be harmed by excessive temp. If no boiling occurred, even 265 F will not harm an engine.
The primary fan on temp is controlled by software in the ECM from the temp sensor at the front of the engine under the MAF. The secondary fan on temp is controlled by a thermostatic switch in the block between cylinders #1 and 3.
When sitting in traffic that provides no air through the radiator, you should experience the main fan come on at 228 F and off at 211 F and then it will repeat. Underway, the coolant should settle at 195 F at the coolant temp sensor in the front of the engine with the factory thermostat.
Old Apr 8, 2012 | 09:50 PM
WW7's Avatar
WW7
Originally Posted by Cliff Harris
There are two or three temperature sensors (if you have the auxiliary fan).
The temperature sensor in the passenger side head between plugs #6 and #8 is the sender for the temperature display in the instrument cluster.
The one on the front of the intake manifold goes to the ECM. The ECM determines when to turn on the main fan.
If you have an auxiliary fan in front of the radiator, it is controlled by a temperature switch in the driver's side head between plugs #1 and #3. You can change the auxiliary fan turn on temperature by buying the appropriate temperature switch.
I just copied and pasted from another thread, it was easier...... Below is a kit to lower your temps if thats what you want to do...You can also change the fan on and off temps in the chip...WW
http://www.ecklerscorvette.com/corve...1984-1995.html
Old Apr 8, 2012 | 09:52 PM
caddyboy84's Avatar
caddyboy84
I did not tamper with the operation of the main fan and it comes on around 228 or so(I made my car get that hot to check the system properly) or when I put on the A/C. So is it true that the primary fan "temp-on-point" cannot be changed without making an ECM modification with a chip? And, what is that temp switch on the rear passenger head for? This is very important to me because I've been handed and passed on alot of misinformation, which I'd never want to do. Although how I have my car set-up seems to be a good working combination and serves it's purpose well, it's not factory parameters.
Old Apr 8, 2012 | 10:03 PM
WW7's Avatar
WW7
If its working well and not running hot, I would leave it alone..Remember the old saying..If it aint broke, don't fix it, this should be a plackard on the C4 Corvette dash........WW
Old Apr 8, 2012 | 10:08 PM
caddyboy84's Avatar
caddyboy84
I've been schooled, and I appreciate it I have a couple of calls to make and some screaming to do. I guess there really is three sides to a story, BS more BS and the truth. There is someone else with a similar thread right now that needs your help, uhhh....I kinda misinformed them.
Old Apr 8, 2012 | 10:17 PM
WW7's Avatar
WW7
The first thing to do is remove the radiator shroud and clean the area between the condensor and radiator..This area is usually loaded with trash that blocks your radiator from cooling properly...Also shoot some water through the radiator fins to clean them out while you have it open...The second thing you can do is flush your system if you haven't all ready done it...After these things the only other thing you can do without replacing parts is to have your chip changed (burned) to make your fans come on sooner or get a kit from Ecklers or one of the other sites to change your fan On/Off temps.. To really make your car run cooler and stay cooler you have to change the radiator to a "High Capacity High Flow" type like a Dewitt's and get a Higher CFM fan to move more air....This is not really necessary on a street car though, I have seen plenty C4s run 190-195 highway with the stock system .....WW
To Temperature Switch
