87 cluster dead after replace bulbs
Old Apr 11, 2012 | 02:12 PM
Ghoghos's Avatar
Ghoghos
Cruising
Default 87 cluster dead after replace bulbs
Any suggestions ?
I change the bulbs not a problem after that the cluster was working w/o showing temperature , I took it out again didnt see anything weir , put it back together and plug it back to the car now I have nothing , not reading with or without the bulbs , any suggestions?
Old Apr 11, 2012 | 02:33 PM
2fas2c's Avatar
2fas2c
if your getting nothing at all the power supply is probably shot.
Old Apr 11, 2012 | 02:41 PM
Ghoghos's Avatar
Ghoghos
Cruising
Is the power supply inside the cluster?
The only thing i can see is when i try to start up it shows same info for a second without the bulbs on ,
Old Apr 11, 2012 | 04:05 PM
2fas2c's Avatar
2fas2c
ah ok your ground is the issue. If you take the cluster apart you will see the interboard connectors, long pins that connect the 2 boards together. The pin on the far right probably has a bad solder joint, flip the board over and take a look, the joints should be shiny like chrome not dull or broken, reheat the joint and add a small amount of solder that should fix the problem. As always do at your own risk I am not responsible for any damage caused, haha sorry had to throw that in there.
To 87 cluster dead after replace bulbs
