harmonic balancer change help
Old Apr 17, 2012 | 11:05 AM
hitmanpty's Avatar
hitmanpty
Originally Posted by mcm95403
Now that I see this I think I'll lift the engine out to do the cam change and head swap when I get to that point.
:rofl :
Old Apr 17, 2012 | 01:54 PM
hogsnvettes's Avatar
hogsnvettes
Originally Posted by hitmanpty
Just like to say. I dont recoment to any one to hit in any way the harmonic balancer. that is a "no no" all the way,
you can damage important part of your motor by doing this.
always use the proper tools.
You will find a long piece of wood and 3lb mallett in most mechanics toolkits. GM harmonic balancers of our vintage are either iron or mild steel and wood is not going to harm it.
Old Apr 19, 2012 | 01:26 AM
hitmanpty's Avatar
hitmanpty
ok after fighting all afternoon with i finaly took it out.
the HB was a mest very bad contion. tomorrow I will try to instal the new one after I fix the thread. I damege the tip just a little I think I can fix that.
here are some pics of the old balancer
[IMG][/IMG]
[IMG][/IMG]
Old Apr 19, 2012 | 09:58 AM
hitmanpty's Avatar
hitmanpty
ttt
Old Apr 19, 2012 | 07:15 PM
ex-x-fire's Avatar
ex-x-fire
Make sure your timing cover is in good shape. Mine wasn't when that happened to my balancer.
Old Apr 19, 2012 | 09:25 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
No need to remove the engine to do a cam swap. I did mine in an afternoon with the engine in place. You have to take at least one engine mount bolt out to lift the engine slightly so the cam will clear the crossmember above the steering rack.
Old Apr 19, 2012 | 10:50 PM
hitmanpty's Avatar
hitmanpty
Fin the thread no my install is no good since the the thread of the tool is to bit foro my car. Tomorrow i Well go out and get new instaler
Old Apr 20, 2012 | 01:00 AM
desertmike1's Avatar
desertmike1
you guys are compairing apples to oranges, the LT1 2 piece ballencer will require from time to time; a few taps to get the outer Ballencer off of the inner Hub. Never use this procedure on a single piece ballencer.
your both right and both wrong on this one...just saying
Old Apr 20, 2012 | 01:12 AM
Cliff Harris's Avatar
Cliff Harris
I used a long bolt and a lot of washers. Tighten bolt to pull the balancer on a little way. Take out bolt. Add washers. Tighten bolt. Add washers...
When I had a '78 Corvette I used a hammer to tap it on, but there is no room for that on a C4.
I just found out that washers are arandelas...
Old Apr 20, 2012 | 09:20 AM
hitmanpty's Avatar
hitmanpty
Sorry about this post.iam using my samsung galaxy and this thing keep changing the letters i type in. No even l undestand What it say .
Old Apr 23, 2012 | 05:58 PM
hitmanpty's Avatar
hitmanpty
ok saturday I install the new harmonic balancer. it was very dificult task. not so much for theisntall it self.but because the little room to work on.
after all after noon finally finish.
next day iset the engone to 6* BTDC with out a problem.
I went for a test drive. no back fire.
next will test fuel preasure
thank you all for all the help. with outthe forum. I will never do it.
Old Apr 23, 2012 | 06:46 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Congrats on the job, bet you feel good doing it yourself now that it is done.
Old Apr 23, 2012 | 08:54 PM
  #33
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I'm doing a cam change right now and I did my balancer removing the exact same way Agent 86 did. In fact I'm almost convinced that is why that hard line has that bend in it like it does. I was even able to use my impact wrench to remove the balancer but my radiator was not in the way.
Old Apr 23, 2012 | 09:15 PM
  #34
desertmike1
Old Apr 23, 2012 | 10:19 PM
  #35
Midnight 85
Another case of our cars being the same but different, my cam came right out with no interferance from that crossmember, It almost came completely out of the block before I had to move the condenser.
