No Power at all..Need Help
Old Apr 17, 2012 | 07:06 PM
16651avenida's Avatar
16651avenida
4th Gear
Default No Power at all..Need Help
New to the forums, This morning started my 85 Vette. The instrument panel flickered once and everything shut off. No lights, no power at all.
Battery is hot and charged. Could really use some help on this. Not sure if its a fuse, or even know where there might be a fuse box other then the one on the right side of dash. New to vettes, alot to learn.
Thanks Dave
Old Apr 17, 2012 | 08:28 PM
John A. Marker's Avatar
John A. Marker
Since you are referring to the instrument panel and no power.....I will make the assumption that the car runs....just no instrumentation.
Chances are that you will have to have the panel rebuilt. Mine did that a couple of times, but came back on. It eventually would not come back on.
I had mine rebuilt by Taber Corvette Parts in Indiana. Person to talk to is Kevin Taber - (877) 349-2838.
Just to give you a heads up. You have to unbolt the two bolts under the steering wheel column and drop the column down to get the panel out. You also have to remove the center instrument panel.
Good luck.
Old Apr 18, 2012 | 01:48 AM
Cliff Harris's Avatar
Cliff Harris
Check here for info on how to fix your cluster:
http://www.batee.com/corvette/dcrg/index.htm
For reference, I have had mine out many times and never unbolted the steering column. Just tilt the wheel down as far as possible and put a rag/towel over the top of the column to prevent scratches. Some people recommend taking out the tilt lever. Mine won't come out, so I have never done that either.
Old Apr 18, 2012 | 08:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like you need to check and see if your battery connections are clean and tight.
Old Apr 18, 2012 | 10:36 AM
16651avenida
4th Gear
Default dead vette
Thanks Dave
Batt. terminals are clean and tight.. Can anyone tell me where the main negative conection is? Well, pos./neg. connections good, engine cranks well if I jump cellenoid. Still no power inside car
Old Apr 18, 2012 | 12:32 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
On the block above the oil filter on the side of the engine. A 19mm head bolt holds it on.
Old Apr 18, 2012 | 03:11 PM
AGENT 86's Avatar
AGENT 86
Old Apr 18, 2012 | 08:32 PM
16651avenida
4th Gear
Default Great picture!!
Originally Posted by AGENT 86
Thanks so much for your concern and help everyone. When I checked the pos. cables at the solenoid nut it seemed like it could go tighter, so thats what I did. Everything came back 100% Thanks so much you guys rule..
David M.
To No Power at all..Need Help
