I hear ya! That would bug me too not to be able to take full use of the lightweight parts. I spent more points on suspension so I am only taking 4 points for weight, and I still have the stock hood and glass.
Your power and torque curves are exactly what I am looking for with my new engine!
C4 of Year Winner (appearance mods) 2019
Originally Posted by mrc24x
@Kubs,
Yeah, I ran 275 'Kooks and I still had to add a ton of weight! I spent all that money on lightweight parts, lexan..etc and it just bugs the chit out of me to put ballast in the car. It's nice to mount it low but it still wears out hubs/brakes and tires.
I'm leaning towards putting the large runner setup back on the car and running at 2951lbs (that includes me/gear and fuel after a 40 minute race). 315's on all 4 and that weight should put me back in the 1.7+ G range. I was consistantly 1.53-1.55 with the 275's.
@Greg, You just want your HSR back!
Shhhhh,,,,Don't tell!
Interesting that race classes have an intake-installed vs weight rule. So, just by installing your Long-tube intake again, you are allowed to run @ a lighter weight?
It's all hp to weight. If I run my old long tubes it would put me ~330-335 rwhp so I could shed the extra weight. **They don't consider Torque in the equation.
No problem...he's right. When I picked/bought my cam, I hadn't decided on a 383 yet. With a TQ setup, it's fine -- even for a 383. With an HSR, I'd probably want more cam -- though I'd try it as-is to see. Or, at least my existing cam in a more-retarded position.
Originally Posted by 88BlackZ-51
do you know the size of the runners after TPIS ported them?
Because TPIS and AS&M runners are mandrel bent (w/o much wall thickness), you can't really hone/port the length of the runners. You can only port-match the base-runner-plenum transitions.
IIRC, they're in the 1.65 ID range. (I.D.)
For comparison, stock is 1.45, SLP is 1.55 and the FIRST are 1.9" ID. Also, SR tubes are about 1.7".
If you use the standard PI*r*r equation, you'll find there's a significant difference in the cross-section of all these sizes....especially going from stock to a FIRST.
IIRC, it's something like 30% going to the TPIS tubes and 50% going up to the FIRST. People tend to forget circle area grows in a higher proportion to the radius. IOW, even tho radius is only about 30% bigger, the cross-section is more than that.
Originally Posted by ch@0s
Yes, it's a Hotcam. That was why I was so surprised at the outcome.
Yeah...I thought. It's the same cam he used in his last TPI version. For comparison, his TPI dyno was linked (by me) in the L98TPI thread that was up about 2-3wks ago....the one where that guy used AFR heads with a TPIS cam....226/226 duration.
Originally Posted by USAsOnlyWay
Matt, is this the combo we ran on DD?
If so, it looks like it wasn't far off, it predicted 394rwtq and 367rwhp.
Enjoy the motor!
Yep...TPIS CNC-ported 113's are a decent head. Much better than hand-porting accomplishes from what I gather!
On paper, they flow darn near the same #'s as AFR 180's. (Flow numbers may still be on their website and/or in their catalog. I remember they're nearly identical to the AFR180's). IIRC, their intake runners pour in the 186-188cc range though...meaning they're port velocity is a hair slower than AFR180s...but still very, very good. The main issue choosing between AFR180 and TPIS CNC-porting would be the quality of the original casting. You read some about porter's punching thru walls, but you'd have to think (and TPIS will assure you) that castings are inspected before accepting/porting. Price is, of course, another consideration. If you have good castings and can resell them, the cost of AFR's isn't much more....Plus, you can opt for the 195's or bigger and get something that will outdo even the CNC-ported stuff.
Bottom line: Results I've seen (including Matt's prior TPIS long-tube intake) show the TPIS CNC-ported heads to run as well as they look on paper. TPIS CNC-ported heads should be a valid contender...and this thread supports it.
Of course, the HSR is a good intake too.
