HSR Dyno Results
Old Apr 19, 2012 | 05:48 PM
mrc24x's Avatar
mrc24x
Default HSR Dyno Results
I had a hard time finding actual dyno results for 350 HSR combos so here's the latest on my build for anyone interested:
Forged 350
TPIS Ported 113's
Hotcam
Hooker 1.75" headers, 3" exhaust, x -pipe and Mufflers
TKO 600
Non Ported Full HSR
Accel DFI 7
24lb SVO's
Old Apr 19, 2012 | 05:52 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Very nice. Gobs of torque. AFRs look spectacular as well!
Unrelated, but could you PM me pics of how you did the TKO to C-Beam? I'll be replacing the ZF eventually and am looking for ideas.
Old Apr 19, 2012 | 06:01 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Very nice!
Old Apr 19, 2012 | 06:06 PM
bjankuski's Avatar
bjankuski
Good numbers.
Old Apr 19, 2012 | 06:16 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Very good Matt! Looks like you got the tune sorted out. Hopefully for good! Looking forward to watching you run in June.
Old Apr 19, 2012 | 07:15 PM
LD85's Avatar
LD85
Keisler sells a bracket
MRC24X, very nice, the HSR is the bomb!
Old Apr 19, 2012 | 07:41 PM
Black89Z51's Avatar
Black89Z51
They sell a bracket for the 4+3 conversion. I thought the ZF to TKO was a bit different.
Old Apr 19, 2012 | 09:11 PM
LD85's Avatar
LD85
I'm pretty sure its the Its the same beam, different yoke.
I went from the 4+3 to the ZF to the TKO and used the same C Beam
You will need 4+3 hydraulics and bell housing
Old Apr 19, 2012 | 09:31 PM
88BlackZ-51's Avatar
88BlackZ-51
making great power for those mods!
Old Apr 20, 2012 | 07:19 AM
mrc24x's Avatar
mrc24x
Thanks for the compliments all! My car was always better than C5Z's exiting 50 mph turns up to 100, but then they would walk me. (TPIS large runners /base)
Now I pull a little on them from 100-150 without losing anything off the slower turns.
Keep in mind, we are all at 8.7 lbs/HP because of class rules but the key is where we make the power.
LD is correct about the Keisler bracket. I have been down the same road,,,4+3 -ZF6-TKO.
I actually like the shifting of the ZF a little better but the extra weight stinks.
Matt
Old Apr 20, 2012 | 07:54 AM
steven mack's Avatar
steven mack
I believe there is an upgrade for the TKO that can make them shift smoother,It's a carbon fiber synchro kit along with some other parts.I also have the TKO trans in my Vette.It's a good trans just a little stiff when shifting between the gears.The numbers you are putting down are great for a 350 with ported 113's.You definitely have your parts sorted out.
Old Apr 20, 2012 | 04:15 PM
l98tpi's Avatar
l98tpi
Max G’s
Nice power curve. What rear gear and what tire size are you running?
Old Apr 20, 2012 | 04:38 PM
ch@0s's Avatar
ch@0s
Wow! great results.. makes me miss my HSR.
Old Apr 20, 2012 | 06:05 PM
5abivt's Avatar
5abivt
expected those numbers good working combo and thats only a hotcam ! With a more aggresive cam and/or heads 400whp is cake although im assuming not within the rules.
Old Apr 20, 2012 | 09:40 PM
ch@0s's Avatar
ch@0s
Man, I wonder what mine would have dynoed at now. My cam was a little more agressive CC502 and I had Vortec fastbun heads. It felt really good for 50 miles.
Old Apr 21, 2012 | 12:38 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Huh...I knew someone would be able to capture exactly what I was thinking!!!
Old Apr 21, 2012 | 11:26 AM
mrc24x's Avatar
mrc24x
3.45 and 275's (because of rules) I still might switch back to my TPI so I can run 180 lbs lighter and use 315's. It really depends which track we run for the best combo. Decisions, decisions...
To HSR Dyno Results
Old Apr 21, 2012 | 05:02 PM
Kubs's Avatar
Kubs
Matt are you using the 275s in ST2? Is that so you can use the mod factor for pwr to weight?
Old Apr 22, 2012 | 12:29 AM
GREGGPENN's Avatar
GREGGPENN
Do it! Do it!
(No one else will get this btw.)
Old Apr 22, 2012 | 09:56 AM
mrc24x's Avatar
mrc24x
@Kubs,
Yeah, I ran 275 'Kooks and I still had to add a ton of weight! I spent all that money on lightweight parts, lexan..etc and it just bugs the chit out of me to put ballast in the car. It's nice to mount it low but it still wears out hubs/brakes and tires.
I'm leaning towards putting the large runner setup back on the car and running at 2951lbs (that includes me/gear and fuel after a 40 minute race). 315's on all 4 and that weight should put me back in the 1.7+ G range. I was consistantly 1.53-1.55 with the 275's.
@Greg, You just want your HSR back!
