possible to wire a/c with just a toggle switch?
Im wondering can i just remove the thing and put 3 switches, cold, hot, and defrost... just make them 100% or off. Would make it a lot simpler. And would save on weight, give me a place to mount other switches and less of a headache.
Im guessing there are a lot of resistor values but i just want a switch that changes the air path to cold, switches the compressor on, and turns the fan to 100%.
Im not paying $300 to get a new unit and hope that fixes the problem. Already spent enough time piddling on it.
The electronic a/c control head is only one portion of a multiple component system that seeks permissions and info from the other pieces...
you still have the a/c programmer and would loose ALL vent control plus you loose hot/cold air blend control.
You would loose auto-cooling fan control.
Your problem is simple. Get the control head rebuilt. There are only 2 things that ever fail in this very reliable system...
1. the BCM (blower control module) if the fan goes crazy or the clutch won;t engage
2. the control head. (if suddenly displays in Klingon)
Often the control head just needs to be taken apart and the contacts on the 2 boards need to be cleaned and the slot tightened for solid contact.
Rebuilt control heads run $75 to $150. Used are available all over flea-bay.
Good advice. No reason to mickey-mouse your way around this, unless you just don't want any HVAC at all.
I would also get an indication of if you are low on Freon. I would check the static pressure and first see what that is. I might also manually run 12 volts to the compressor and get it turned on and continue to check the pressures. You would have a more complete picture of the Freon and problem.
After that if not progress is made, all previous is good.
If the radiator cooling fans are not running: on a 90 the fan relay ground wires need a switch to ground to turn them on manually..
Now that I'm thinking about your problem I have some spare AC parts for an 89 that I collected when I had one many years ago. Will look for them after lunch.
Have a used 88-89 programmer group 9.275 (C68) 16069591 if you need one.
Then it was working about 90% if the control in the cab wasnt on the fritz. Then i changed my intake to a high flow manifold and it was during the winter and i didnt use the ac for a long time then one day went to turn it on and it didnt do anything.
Then about every day or two the thing flashes all the lights in varying order like a demo on a stereo and the number display never looks right until i press the off button like 10 times and then it will go back to read 75. But no controls will respond. The light will come on saying that i have chosen say ie defrost but no compressor or fan comes on.
I just have other stuff i want to spend time on other than figuring it out, i guess ill try manually testing the compressor.
