fuel pressure
Old Apr 27, 2012 | 11:43 AM
senter9's Avatar
senter9
Default fuel pressure
Does anyone know the stock fuel pressure PSI for a 93 LT1
Old Apr 27, 2012 | 08:44 PM
93Rubie's Avatar
93Rubie
38 PSI with vacuum line on fuel pressure regulator. 42 PSI with it off. That is what mine is.
Old Apr 28, 2012 | 12:43 AM
senter9's Avatar
senter9
Thanks rubie
Old Apr 28, 2012 | 06:53 PM
NTL1991's Avatar
NTL1991
Just an addition, according to the FSM, it can be as low as 31PSI with the vacuum line on an still be within spec.
Ignition On, Engine Off: 41.0 to 47.0 PSI
Engine On, Regulator Vacuum Applied @ Normal Idle: 3 - 10 PSI less than Ignition On, Engine Off.
To fuel pressure
