Charging problems
Old May 4, 2012 | 11:57 AM
BOTY79's Avatar
BOTY79
Originally Posted by WW7
New AC Delco alternators use to come with a sheet inside that told you to charge the battery before installing the new unit or diodes could be blown.. Its been quite a few years since I purchased a new alternator, but I believe it had something to do with a surge if the battery was low......WW
First where does the single red wire go (not the one in the pig tale )?
Here is what i have done today rebuilt alt from new source, new pigtail, new battery. Start car same problem 11.8 at fast ilde on three different gauges all reading same ,once warm it goes to 11.4.
Will go and see what readings i get at the above mentioned places.
Old May 4, 2012 | 12:14 PM
Phat98's Avatar
Phat98
Originally Posted by caddyboy84
I hope that an electrical whiz chimes in here, because I really don't want to believe ya got all those bad alts. Man, if thats the case, I would NEVER go to that store again
I went through SIX heater cores in ONE month on the ex's '97 Bonneville. They discovered the Mexicans were using low-grade solder and the antifreeze would eat through them in a couple of days. BTW, these were AC/Delco cores installed by the Pontiac dealership.
So yeah, I believe you could get a row of bad alternators no matter where you got them...chit happens, ya know?
Old May 4, 2012 | 02:52 PM
BOTY79's Avatar
BOTY79
Thanks to 94z07fx3 the single red wire was corrode at the terminal and i did not see it till i cut the boot off as it had hardened up. If it wasn't raining i would be out for a ride
Old May 4, 2012 | 03:27 PM
caddyboy84's Avatar
caddyboy84
So you're saying after all this, it was the power wire on the back of the alt? I don't have that boot, I have a plastic cover that "snaps" over the lug that you have to remove to expose the wire when you take it off. I would think you'd have to pull that boot back to un-do the nut and you would've seen that. Oh well, it's hard not being there to see for ourselves.
Old May 4, 2012 | 06:09 PM
WW7's Avatar
WW7
Well, at least he can stop putting on alternators now......WW
Old May 4, 2012 | 06:12 PM
94z07fx3's Avatar
94z07fx3
Old May 4, 2012 | 08:21 PM
caddyboy84's Avatar
caddyboy84
Yep, you're not kiddin. Not like me havin to take my injectors out THREE times Alot of cursin that day
Old May 6, 2012 | 12:57 PM
BOTY79's Avatar
BOTY79
Thanks to all of the advice, it is nice to have to know you can get on here and get some sound advice.This is what trhe FORUM is all about.
