wheel removal
wheel removal
I have an 89 with stock wheels. the key to remove the center caps is stripped and am looking for ideas on how to remove the center caps so I can remove the wheels. I don't care about damaging the bolts that hold them in place. any ideas would be helpful
I always got locks off by banging a slightly smaller socket onto it . Don't ask how I know that.
Are those the huge center caps with a single keyed bolt holding them on?
If so when I had an 88 I had a similar issue and was able to make a really thin flat blade screwdriver and very thin needle nose pliers to work the bolt loose and get it out.
Suckin' gas, haulin' ass.
If the above doesn't work, you can try to get a reverse rotation drill bit that's smaller than the threads and drill it a little ways. Sometimes the friction of the drill will back it out. If not, then use a broken bolt removal tool. Try to find the square ones. I've had bad luck with the spiral fluted ones.
caddyboy the smaller socket trick wont work on this one i'm afraid and the your worst case scenario; oh boy that is last option cause I can see being able to get a pair of vise grips onto what will be left
jaa1992 it is as you discribed and looks like i'll spend the first half of this Saturday AM trying your suggestion and if that fails
Black89Z51 your suggestions will be attempted in the afternoon if my patience grows weary in the morning.
Thank you all for the suggestions I might have a major wheel purchase in the future. I wanted to put it off until the winter but I got a loose lug nut rolling around in there
