Code 23
Old May 9, 2012 | 02:05 PM
armybyrd's Avatar
armybyrd
Default Code 23
Ive got an intermitten code 23 on my '88. I just looked it up in my fsm but dont understand everything so Im hoping to get the translation in common terms. Is the MAT sensor the one right under the plenum? Is it only for egr? My egr is blocked off and it should be included in my tune from pcmforless if that matters. Also in the fsm what does CKT mean? Also what symptoms will this code produce?
Old May 9, 2012 | 03:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
CKT= Circuit
Yes, only used for EGR.
Unplugged or broken wire or broken sensor, will set 23.
Old May 9, 2012 | 03:36 PM
armybyrd's Avatar
armybyrd
I just happened to read one of the older threads debating whether the MAT controlled fuel/spark on MAF cars. Does this mean my tune left the egr code out or is that only to keep a code directly related to egr off? So in other words I should disregard this or would it make a difference having this sensor still in place unplugged?
Old May 9, 2012 | 05:41 PM
AGENT 86's Avatar
AGENT 86
The MAT SES light is not affected by them turning off the EGR code.
Fix the circuit or deal with the light coming on.
To Code 23
