Lt4 Roller Rockers?
Old May 11, 2012 | 11:26 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Lt4 Roller Rockers?
I have a set of roller rockers. They came of a set of LT-4 heads I believe they are factory items. I like a positive I.D.. If you have some LT4 roller rockers can you tell me what they say on top? Thanks!
Old May 11, 2012 | 11:55 AM
96GS#007's Avatar
96GS#007
OEM LT4 rockers looks the same as what came with the LT4 "kits" and over-the-counter LT4 cylinder head setup sold by GM. You need to look at the rocker arm studs. OEM studs have a tapered seat vs a standard stud used by the LT4 upgrade kits.
Below is a pic of my the rockers from my GS. Note what the studs look like. Very different from a traditional stud.
Top is a standard 3/8" stud and bottom is a OEM LT4 10mm tapered stud.
Old May 11, 2012 | 03:26 PM
87bob's Avatar
87bob
Your picture answered my question. They have the bowtie logo under it is CR and 2 2digit numbers one pair on the left and one on the right.
and they are in the aluminum finish.
Thank you much for your response!
To Lt4 Roller Rockers?
