What to replace?
Old May 15, 2012 | 12:02 PM
Lexdog10's Avatar
Lexdog10
3rd Gear
Default What to replace?
I'm getting my injectors replaced in about a week (Thanks FIC!) while I had everything opened up I was wonder if there was anything you guys recommend I replace or at least look at. I have a 1991 6 speed that is all stock. Thanks for the help!
Old May 15, 2012 | 12:55 PM
summerst's Avatar
summerst
Replace the EGR valve at the same time. Easy access with the plenum off. You may want to buy a can of carb cleaner (Gum Out or Walmart generic equivalent) and spray the chamber below the EGR valve thoroughly to get the 20 year build-up of black crap out of there before you replace the EGR. My mechanic spayed it like crazy and used a wire coat hanger to make sure the passages were clear. Don't forget the buy the gaskets for the plenum and new o rings for the fuel rails. Make sure you test each new injector using an ohm-meter. I know that everyone says that the ones from FIC are fine, but it only takes a few minutes to check and, remember, you and your wallet have to do the replacing if (perish the thought) FIC sent you a bad one.
Old May 15, 2012 | 01:11 PM
caddyboy84's Avatar
caddyboy84
When I did my injectors (BoschIII 22's from F.I.C.) I changed the fuel pump, the filter and the relay, I wanted everything to be fresh with no weak-links . I don't think you need to change the egr if its working, why waste a c-note, just depress it to see if it opens. I also changed my stat while I was there, what the hell.
Old May 15, 2012 | 01:14 PM
ch@0s's Avatar
ch@0s
While you are there get an adjustbale fuel pressure regulator and new diaphragm. Also, take the time to port and clean up your plenum. Maybe even have it powder coated. They look great when done right
Old May 15, 2012 | 01:16 PM
caddyboy84's Avatar
caddyboy84
How did I forget; While I was there I also refinished my valve-covers, plenum , new regulator and powder-coated my runners Might as well, no?
Old May 15, 2012 | 01:18 PM
caddyboy84's Avatar
caddyboy84
Yep, yeppers I also did the cap, rotor, plugs ,module and wires.
Old May 15, 2012 | 01:41 PM
caddyboy84's Avatar
caddyboy84
The more I look back on it, the more I remember. I replaced all the old plastic wire looms and dirty old electrical tape. I removed the square plastic factory wire covers above the valve-covers and the bolts in the manifold. I replaced them with new black wire-loom. Now is the time to do everything that is within reach while it's apart, who wants to take everything apart again to do it all later. I took my time and spent a week getting everything MINT
Old May 15, 2012 | 02:57 PM
summerst's Avatar
summerst
My mechanic checked the old EGR valve and it opened fine. I had it replaced anyway as added insurance. Had we not pulled the old EGR, we probably would have not cleaned out the EGR chamber. Bought the EGR valve (BWD EGR114D) from Advance Auto Parts for $57.77. If you have one close by, you can avoid shipping by picking it up at one of their stores. Use a coupon like A123 and get $20 off that price or BIG30 and get $30 off if you bundle the purchase with other items to get you over $75. Buy through fatwallet.com and get 10 percent off the total purchase as a rebate through fatwallet.com. You have to join fatwallet.com but if you buy anything from Advance Auto Parts, that is how you save the most and you can find all the valid coupons on their site. With all the discounts, that comes to $33.99 plus tax (using A123) or $23.99 (using BIG30) if stocked at your local Advance Auto Parts.
Old May 15, 2012 | 03:10 PM
caddyboy84's Avatar
caddyboy84
I guess it dosen't hurt to change the EGR, I guess maybe I should've went with a new one seeing all the money and time I spent, but I try and save some cash when I can. I saved all the parts I changed-out with new ones as spares, at least I know they all work if I ever need something. An engine builder friend suggested doing the intake gasget while I was there, Maybe I should've.
Old May 15, 2012 | 03:12 PM
Muffin's Avatar
Muffin
HALP, QUICKSAND, Not one person has said a thing that isn't correct but the more you move around the deeper you sink.
Old May 15, 2012 | 03:13 PM
ch@0s's Avatar
ch@0s
Oh yeah .. I started with a leaking intake gasket.. then heads ..now an LSX..
Old May 15, 2012 | 03:18 PM
caddyboy84's Avatar
caddyboy84
At first, I gave myself a cash budget. Well, a few grand later I'm trying my hardest to STOP THE MADNESS!! I just ordered 4 more things from 3 different places, there goes another "nick"
Old May 15, 2012 | 08:24 PM
summerst's Avatar
summerst
On my 1990, I wished I changed the intake gaskets at the same time had I known there was a slight leak in the back of the manifold. At the time, however, I had just purchased the car and it had been sitting so long, I did not see any evidence of a leak. I was just focused on finding out if my new "ride" could run as I bought it "as-is" with what I believed to be bad injectors (which I had just learned about the hard way on my 1991). I was right about the injectors and, since November 2011, I have put 2,000 local miles on my "new" daily driver. BTW, I have learned to live with the little drop of oil (cardboard in the floor of the garage picks it up fine). Still, if I had known more about the car, the intake manifold would have been pulled.
Old May 16, 2012 | 06:16 AM
caddyboy84's Avatar
caddyboy84
I hate when that happens My intake wasn't leaking but it would've been nice to really clean it up off the car, though I cleaned it best as I could. The engine was rebuilt in 07 and I guess it could've used a changing. I get CRAZY when I start "going to town" and can't stand the look of a new part against old dirty stuff. This is the recipe for falling into QUICKSAND!! But it was worth it, the car looks and runs MINT A friend and I argue about this all the time (for years) and I'm a detail fanatic who firmly believes that a car should look as good as it runs. Who wants to open a hood and see a dirty greasey engine?
Old May 16, 2012 | 07:19 AM
Thorr's Avatar
Thorr
Whatever you do, don't let the factory smoke out of the wires. Once it gets out, you can't get that stuff back in.
To What to replace?
