Header Install
Old May 22, 2012 | 04:28 PM
shamdave's Avatar
shamdave
Default Header Install
How hard is this to do on a 1985? is this something that can be done with a jack and jack stands or do you need a lift?
About how many hours am i looking @
Old May 22, 2012 | 04:32 PM
caddyboy84's Avatar
caddyboy84
I want some answers about this myself. I've done alot of headers over the years and they were always a bitch and they always leaked.
383vett's Avatar
383vett
I've taken my longtubes on and off a zillion times with the car on jackstands. First time will take a few hours. Afterwards, much less.
Old May 22, 2012 | 04:49 PM
Alan777's Avatar
Alan777
What needs to be removed to allow access?
Old May 22, 2012 | 05:37 PM
nutz4c4's Avatar
nutz4c4
What brand of headers?...
Old May 22, 2012 | 05:45 PM
Crepitus's Avatar
Crepitus
This might help you out;
http://www.holley.com/data/Products/...2149HKRrev.pdf
Old May 22, 2012 | 05:53 PM
black88z51's Avatar
black88z51
it was a real PITA to do on my 84. 1 full day for 1 guy. And after all that I didn't like them.
Old May 22, 2012 | 05:54 PM
ch@0s's Avatar
ch@0s
Easy I did mine in my garage on ramps all i had to do was have my Y pipe welded for $30 bucks.
http://forums.corvetteforum.com/c4-t...te-videos.html
Old May 22, 2012 | 06:06 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Do you have Melrose's headers?
Old May 22, 2012 | 06:22 PM
shamdave's Avatar
shamdave
I havent bought mine yet I am leaning tword hookers
Old May 22, 2012 | 06:25 PM
shamdave's Avatar
shamdave
Originally Posted by Crepitus
so its worth the $500.00 bucks I was quoted. (for all the material (mufflers pipes every thing installed) plus the cost of the headers
Old May 22, 2012 | 06:34 PM
ch@0s's Avatar
ch@0s
Depends on what headers if they are not coated they cost $150.
Old May 22, 2012 | 06:41 PM
shamdave's Avatar
shamdave
I have to supply the headers and he will supply and do every thing else
Old May 22, 2012 | 06:44 PM
ch@0s's Avatar
ch@0s
Save yourself the $500 and get the hookers and y then do it yourself.
Did you look at my thread?
Old May 22, 2012 | 06:53 PM
nutz4c4's Avatar
nutz4c4
Yes...Yes I do..
Old May 23, 2012 | 02:21 PM
JoeIVZ51's Avatar
JoeIVZ51
This doesnt sounds like that bad of a job...I was really flirting with the idea of getting longtubes. I was either going to get OBXR or Hedman. The hedmans I was looking at dont support EGR however but cost $300 less. Anyone know whats more cost effective?
Old May 23, 2012 | 02:51 PM
IAFF alumni's Avatar
IAFF alumni
I opted for Jet-Hot coated stainless long tubes.
Life is too short to go half way.
To Header Install
Old May 23, 2012 | 02:54 PM
96GS#007's Avatar
96GS#007
meh Header install was a snap, only took a few minutes per side....
Old May 23, 2012 | 03:40 PM
RocketSapp's Avatar
RocketSapp
I installed a set of Headman headers on my 89 in a very small garage with the front and back of the car up on jack stands. I was in the process of replacing the rear drag links and tie rod ends in the back and decided that since I had part of the car torn down while waiting on parts, I might as well start on the headers.
It took my son and I about two or three hours to get them on and all tight. (He was 13 and I was teaching him at the same time.) It's been a few years since I did that so I can't remember if there were any "got yas". If I recall correctly I pulled the starter which helped get the headers in, but it was a mother to put it back on. You have to twist it a certain way and hold your mouth just right (in a spot where crap falls in your mouth) to get the headers and the starter installed.
Once I got the headers on the car and the rear end put back together I drove to the alignment shop down the street to get the rear end aligned. I then drove across town with open headers to the muffler shop. I had him put in 3" pipes, 2 random tech universal cats, and a pair of Flowmaster Delta 40s. While he was there I had him add a pair of dumps at the back of the car right before the pipes bend over to the side of the car.
I say go for it... If anything do it so you can drive it to his shop with open headers. :-)
Tim
Old May 23, 2012 | 05:36 PM
shamdave's Avatar
shamdave
Dumb question I Know, but why not buy the cheap 179.00 headers and paint them? what is the difference then?
