tps signal
Old May 30, 2012 | 05:41 PM
etsfl's Avatar
etsfl
Default tps signal
On a 96 vette the TPS is showing a reading of between 14 and 17 at idle .
Installed a new TPS and getting the same readings. RPM at idle varies from 450 to 1000 and eventually stalls.
The car drives with no hesitation or loss of power.
Connector to TPS looks solid.
What could be the problem?
Old May 31, 2012 | 02:20 AM
Cliff Harris's Avatar
Cliff Harris
First a disclaimer: I own an '86 and a LOT of things changed in the following 10 years. That said, I think your reading of 14 to 17 is OK. Back in my day they said to set the TPS to .54 volts, which is roughly 10% of the reference voltage of 5 volts. I think the 14 to 17 is a percentage, and you're probably in the ballpark with those numbers. Your TPS sensor is not adjustable, so you don't have to worry about that. The ECM looks at the TPS reading when you turn on the ignition and saves that reading and calls it "idle".
99.99% of the time a wandering idle is caused by a vacuum leak. One way to find a vacuum leak is the Scotty Kilmer "smoke test":
http://www.youtube.com/watch?v=zMok2y05jNE
You should pull the error codes to see what the car's computer thinks is going on:
http://corvettephotographs.com/c4vettes/codes.htm
http://forums.corvetteforum.com/1576116036-post35.html
Old May 31, 2012 | 10:58 PM
93Rubie's Avatar
93Rubie
How are you reading this? Is this a percentage? What is the voltage?
Old May 31, 2012 | 11:28 PM
pcolt94's Avatar
pcolt94
I have the same question also. Can't be a voltage, max is 5.0.
Problem sounds more like a bad IAC (idle speed control motor).
To tps signal
