Hard starting problem with 94 LT1
Old Jun 2, 2012 | 09:24 PM
mjmeyerpa's Avatar
mjmeyerpa
Default Hard starting problem with 94 LT1
I recently purchased this car and it is in exceptional condition with less than 50K miles. It began to take repeated attempts to start and I suspected the pressure regulator. Installed a new on with no change, so I installed a new fuel pump as I assumed it was a bad check valve. No luck, and the pressure still falls off to 0p.s.i. in less than 1 minute when turned off. Could it be a bad injector ?
Old Jun 3, 2012 | 12:07 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Do not have an answer to your problem. However my ole 85 starts instantly when I turn on the key and listen for the relay to make a noise that tells me the fuel pump was activated and now start up the car. Do this hot or cold engine temps. I even do the same procedure with my 96 Monte Carlo.
Old Jun 3, 2012 | 10:57 AM
aminnich's Avatar
aminnich
Just 4 bolts to remove the fuel rails with the injectors attached. Then set them on a piece of cardboard and turn on the key. If one leaks you will see it and probably very quickly. Be sure to do this in a safe place as there might be a gas leak going on.
To Hard starting problem with 94 LT1
