Clutch and slave cyc. bleeding procedure
How it works is I drilled two holes in the cap of a new bottle of brake fluid. Then you stick a length of .25 vacuum hose in one hole and make sure it goes to the bottom of the bottle. for the second hole I turned the pressure of my air compressor to about 6#, I used an air gun with a rubber tip.
I hooked the vacuum line in the brake fluid bottle to the bleeder on the bottom of the slave cyc. cracked open the bleeder and using the air gun I pushed it into the open hole on the bottle cap and pulled the trigged for about 4-5 seconds stopped and check the resivoir on the master cyc. it was half full ( I had emptyed the plastic bowl before started). went back under and repeted the blow thru untill I had fluid coming out of the plastic bowl. I had put plastic under the master so I could minimized the brake fluid getting in places it don't belong
I know they sell the pressure bleeder kits. but where I live is 25 miles from the nearest parts store and working by my self most of the time I liked the fact that I could put something together and have it work
and finished the job in 10 minuets where took me most of the day before and never did al the air out
Hope this will help out someone if they get stuck
Mike
Love the ingenuity on the pressure bleeder. I'm often working on th car when shops are closed and have to get creative with tools if I want to get to my goal for the night.
:thumbsup:
You weren't able to bleed it with the slave in place were you? (As others mentioned, I'd think you'd need to unbolt it to get to the bleeder screw, but I could be wrong)
*edit* you probably have a later design with the bleeder on the bottom, don't you? For my 90, the bleeder is on the top of the slave
My only concern about using my air compressor would be with moisture. Even with a good filter, water gets by ...
