HYPERFLEX HELLLLLLLP (rear only)
Old Jun 11, 2012 | 11:45 AM
nomad253's Avatar
nomad253
Default HYPERFLEX HELLLLLLLP (rear only)
I'm working on the rear suspension and have it all in pieces polished and laid out already for bushings.. I tried all weekend to figure out the rear dog bones/control rods and have no clue which ones to use. I have the full hyper flex with black poly/ and the directions are soo generic that I'm lost. I tried all Saturday and most Sunday. Spent all Sunday night searching the forum for the answers but found nothing. Can anyone please give some advice and or tips on what goes on what for the hyper flex in the rear. Sorry I'm a NOOB
Old Jun 11, 2012 | 01:44 PM
nomad253's Avatar
nomad253
ttt
Old Jun 11, 2012 | 01:48 PM
383vett's Avatar
383vett
Sorry, I'd like to help but I have no clue what Hyperflex is. I can only assume it's a company that makes poly bushings. At this point, just go by pictures posted on the forum and trial and error. Maybe calling the company will help. Good luck.
Old Jun 11, 2012 | 01:50 PM
nomad253's Avatar
nomad253
im sorry i should have said energy suspensions lit. its called the hyp;lex system. thanks
Old Jun 11, 2012 | 03:58 PM
96GS#007's Avatar
96GS#007
Guess I don't understand the question. Remove old rubber bushings, slide in new bushings. Pretty obvious if they fit or not.
Maybe a pic would help
Old Jun 11, 2012 | 04:10 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Your having trouble choosing the correct pieces for the dog-bones?
Old Jun 11, 2012 | 04:22 PM
nomad253's Avatar
nomad253
i have the whole hyperflex kit, there are about 7 individual bags of parts included. after that the parts for the dog bones are not easily identified. and the instructions are generic so i am lost.
i could just try them on and see how it goes but im afraid of improperly installing
Old Jun 11, 2012 | 04:35 PM
Caboboy's Avatar
Caboboy
IIRC the large bore mounts on the hub end..........it's been several years though. You should be OK, if they fit they're good.
Old Jun 11, 2012 | 09:06 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Every bushing has a part # cast into it. The instruction sheet lists the part # for each location.
Do you need a scan ?
Old Jun 14, 2012 | 10:27 AM
nomad253's Avatar
nomad253
thanks all for the replies i just went ahead and called them up but thanks for the input and the pic above really helped. this forum is the sh*_T
To HYPERFLEX HELLLLLLLP (rear only)
