Tach filter
Old Jun 22, 2012 | 11:40 AM
bearcat1982's Avatar
bearcat1982
Default Tach filter
I just changed my ignition over to MSD, dist. coil, wires,and 6AL box and my Tach goes crazy on acelleration and MSD says to bypass the tach filter. Can anyone tell me whwere that is at on a 94
Old Jun 22, 2012 | 11:59 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Should be a little round piece in a bracket on the firewall. Follow the tach signal wire from the distributor. It will lead right into it.
Old Jun 22, 2012 | 01:59 PM
WW7's Avatar
WW7
On my 89 it was mounted on the top bolt on the transmission housing.. The 94 could be different but like mentioned follow the tach wire to it....WW
Old Jun 22, 2012 | 09:28 PM
pcolt94's Avatar
pcolt94
Actually the distributor is the opti and those wires go to the PCM. The tach filter is actual connected pin "A" of the hot coil. There are 2 pin "A"s and it is not the dark green wire. If you trace the correct pin "A" you will probably find it. I cannot tell you exactly where it is.
An 89 has a real distributor and much different.
Old Jun 23, 2012 | 08:55 AM
bearcat1982
Thanks for the info everyone,I called the dealer and found out that it is the small rectangle shaped box right off of the coil connector. Acording to MSD when i bypass this filter it will fix the problem i just havn't got to it yet...
Old Jun 23, 2012 | 12:13 PM
pcolt94's Avatar
pcolt94
When you say byass what exactly do you mean because one end of the filter goes to ground. It is not an "in line" connection.
So the only thing you can do is to remove it. Otherwise if you connect across it, you would be shorting the coil to ground and then you will blow the fuse and possibly damage the coil or ICM.
Removing it won't hurt anything. If things are worse with your tach, then that was not the problem and it is something other.
Old Jun 27, 2012 | 09:13 AM
bearcat1982
I found the tach filter, it is off of the coil wires. It has 2 white wires and 1 black wire going to it. I am thinking all I need to do is jump the 2 white wires together??? Would you agree??
Old Jun 27, 2012 | 11:07 AM
pcolt94's Avatar
pcolt94
Are you really sure you found the tach filter. Where did you find it. How sure are you that it is the tach filter. There is a connector type unit near or under the TPS. That is not it if that is what you got. However it does have at least one white wire from it.
I would not recommend shorting anything out or you might be in for a "world or grief". That’s some chance you are going to take with a car of this age and availability of major parts.
The FSM only shows the filter as having 3 connections. Not even sure that it has 3 wires as one connection might be the base itself.
I can't give you a definite answer, but before you EVER short anything out you better know 150% that you are on the right points and know exactly where you are in a circuit.
Got a picture.
Old Jun 27, 2012 | 11:25 AM
bearcat1982
I drove the car to work today so i will take a picture when i go to lunch
Old Jun 27, 2012 | 12:04 PM
Hooked on Vettes's Avatar
Hooked on Vettes
That will work.
Scroll down to page 12. It describes two methods.
How to bypass or eliminate the tach filter.
http://www.delteq.com/Rev5c_Vette.pdf
Old Jun 27, 2012 | 12:37 PM
bearcat1982
Thanks for that info! I will remove the filter and connect the two white wires....
Old Jun 27, 2012 | 01:03 PM
pcolt94's Avatar
pcolt94
That’s a great picture and with that knew what I was looking for.
I really never looked for it, knew it was there and took some digging but I did finally find it wrapped up in electrical tape. It was hard to see under the hoses and wiring also.
I now think Barcat is in the right place and have more confidence in his course of action. I just did not want him to find any smoke.
Old Jun 27, 2012 | 01:57 PM
bearcat1982
Just cut out the Tach filter and my Tach works fine and also my Service ASR light went out and it now works fine!!!!And now my ingnition swap to MSD is complete and all is well!!!Thanks for all the help!!
Old Jun 27, 2012 | 04:20 PM
pcolt94's Avatar
pcolt94
Good job. Glad it all worked out so well.
Now we all know where that filter is thanks to the Baltimore connection.
To Tach filter
