AC scenario
But, after the evaporator, on the low side line going back to the accumulator and compressor, the lines are very cold.
I am wondering, does it increase efficiency significantly, if I were to insulate those lines to keep the system from absorbing heat along those lines ?
And also, as any physical chemistry student knows, compression of a gas above its inversion temperature causes it to increase in temperature - does it also benefit if we can put cooling fins along the high side lines ? Indeed, the condensor is theoretically where the heat is to be dissipated, but has anyone ever put fins on the high side lines ?
What would be good is a heat exchanger between the low pressure side after the evaporator that absorbs some of the heat from the high side line after it exits the condensor. Then, I bet my R134-A would blow maybe almost cold as R-12
But I believe the evaporator temperature is limited or governed by the boiling point temperature of R134 (vs R12) at a given pressure at the expansion valve. I don’t think a cooler liquid line back to the expansion valve will make a lower boiling point into the evaporator.
I just know that more will add to this with more information.
When heat is permitted to enter the system, say, for example by the cold low pressure side's lines absorbing heat, the cooling efficiency is reduced.
So, I took some of that pipe insulation and covered up the low side line everywhere I could under the hood.
It was kind of dumb to have the cold, low pressure side line routed in the path of where the heat from the condensor blows. I swear I can feel a difference now but it might be my imagination since I did not measure any numbers. But in principle it should be cooler and that agrees with what I think I'm observing. At any rate, it can't hurt to prevent heat from entering the system by insulating the low pressure side line between the evaporator and compressor.
When it exits the evaporator it should be all gas and starts to warm up on its way to the compressor. By keeping those lines insolated as you indicated, why would it help the evaporator temperature.
When it exits the compressor as a high pressure gas, the temperature is very high.
However in the car the lines are short and I don’t know if a real benefit would be achieved with the insulted lines. I know it would be a cost for the car companies, but you would think they would insulate them if there was a appreciable gain.
Having said all that stuff now, my 280ZX Datson has the cold line wrapped. There probably is a technical reason to wrap the pipe but I guess we'll have for wait for the answer from SunCr.
If the gas entering the compressor is cooler, then the compressed gas out might me cooler also. But how would this help? The condenser is trying to get the gas down to a liquid so I could see it from that point of view.
*** Me too, would need to meaasure gas temp as it exits evap, and compare to the compressor inlet temp.
*** Since the gas is always above its inversion temperature, upon phase change, compression, there will be a release of enthalpy andcondensor dissipation is the only effective remover of heat , reabsorbtion of heat dissipated by condensor into the compressor inlet is counterproductive to cooling. Guess that's the easiest way I can think to say it. Works for me, I had extra pipe insul laying around, cost me nuthin and I think its cooler.
Anyhow, it would have been cool if you had taken a data point or two before wrapping..
I only used the home-depot style stuff you use on home water heater hot line, polyurethane pre-bored, it comes off pretty easy. My trouble is I don't have infrared thermometer or other way to measure the temps. I have two heat pumps at the house and those lines are insulated too.
What's the air temp under the hood on a 100 degree day ? I'd guess hotter in some places than others but where that low pressure return line runs, its probably about 195. There's only a barely perceivable difference between the condenser inlet and outlet, by hand touch (caution) and I'm amazed at the cooling we get in the first place.
Most of the cooling for the condensor comes from those fans and they're limited obviously. A bigger condensor might be a nice thing to have.
You will get colder 134 air at low vehicle speed by increasing air flow through the condenser.
If both radiator fans do not run when the AC is on tie the fan ground wires together @ the relays so they do. Adding an aftermarket cooling fan in front of the condenser will also help.
I think you can get a rough idea if the difference is enough to measure. But you would really need same conditions for the best (accurate) results. Engine temperature, ambient temperature of air, same speed and sun intensity would all need to be pretty close to really be fair.
If running radiator coolant through the throttle body when its cold outside is enough to help the engine perform better, then cooling the throttle body ought help performance by cooling the intake air charge.
lol, I'm way out on a limb now.
http://www.checkthishouse.com/11/ref...nsulation.html
Why should a car's system behave differently ? Weaker compressors ?
How does insulating the low pressure line cause a pressure drop ? Does it cause similar pressure drop when ambient is 20 degrees less ?
If insulating is bad, then there must be some factory spec for how much heat the suction side is supposed to absorb from underhood, but that
would perhaps sound a bit ludicrous.
http://www.bobistheoilguy.com/forums...Number=1757656
These things leave the Factory with a five minute suck and fill and the only test is a computer scan of the Pressure Sensor. The Accumulator cleans up the quickie by the Manufacturer, but relying on it to constantly deal with liquid or complete liquid? I just don't feel that lucky, even doing it myself. If you are going to do it, I'd get superheat before and after at the Evaporator outlet and Compressor Head (though after may be too late if the charge was questionable to begin with). If you want to gain 1 or 2 degrees on a 100 degree day, remove an oz or two - assuming you have the equipment - or go to a shop, let them suck it all out and put in a balanced charge, and then, with a thermometer in the Center Vent, add and subtract until it gets the lowest temp.
I like the forum here a lot better: www.ackits.com as the guys actually do mobile a/c for a living and though it's been awhile since I hung out there, this topic comes up from time to time.
I ran mine with insulation a couple days now in 105 deg weather and its been nice and cold. I'll run it this summer then look for visual signs of corrosion in October when the avg. daily temps here drop into the 80's.
