under hood lights
Old Jun 27, 2012 | 09:06 PM
Silent Thunder's Avatar
Silent Thunder
Default under hood lights
OK just got my 1996 Vette 3 weeks ago. Open the hood, lights under the hood do not go on. Started the car and turned on the headlights still no lights. Could be a switch or bulbs but first I need to know when they normally come on? All the time with the hood open or only at night with the lights on?
Old Jun 27, 2012 | 09:27 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
When you have a problem it helps if you post the year of your vehicle.. They are only on when the hood is up..
Old Jun 27, 2012 | 09:30 PM
Silent Thunder
I think it may be the mercury switch in the socket. Do these cars have two or only one mercury switch?
Old Jun 27, 2012 | 09:40 PM
ccrazor's Avatar
ccrazor
They have two, one for each..
Old Jun 27, 2012 | 09:50 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Follow the wiring back into the nose area. There is a connector for each, that the previous owner may have disconnected.
Common practice.
Old Jun 27, 2012 | 09:53 PM
Silent Thunder
OK, will do, thanks.
Old Jun 27, 2012 | 10:14 PM
aminnich's Avatar
aminnich
By the vacuum ball in the left front well there is a weatherpack with a 10A mini fuse in it. I would bet the PO pulled the fuse.
Old Jun 27, 2012 | 10:18 PM
Silent Thunder
Nope, just checked it. 10 amp Fuse in tact and good.
tntwolt's Avatar
tntwolt
pulled my entire bulb socket assemblies out. i`ll be changing to leds, using the original bulb holder so the gravity switch still works. thinking about using led driving lights. and i may wire a switch where fuse is so it can be shut off if hood will be up for really long time, when i find the fuse.
Old Jun 28, 2012 | 04:36 AM
Cliff Harris's Avatar
Cliff Harris
I put a black rocker switch in the circuit on both sides to turn off the lights (and ran the wires inside the hood reinforcement). The round thing below the switch with the 3 dimples is where I plugged the hole that the rubber grommet was in. Sorry for the fire extinguisher powder everywhere -- I had this little fire...
Old Jun 28, 2012 | 08:23 AM
AGENT 86's Avatar
AGENT 86
Nice idea, Cliff
Old Jun 29, 2012 | 02:52 PM
Sworn's Avatar
Sworn
St. Jude Donor '12
Common practice.
MY P side under hood light was disconnected. I plugged it back in and now both lights are on.
Question, why is this common practics? Is it to save the battery? Thanks!
Old Jun 29, 2012 | 03:13 PM
AGENT 86's Avatar
AGENT 86
Yes, save battery. Lots of members have their hood open for long periods of time for repairs or car shows.
My hood has been open for 8 months.
Old Jun 29, 2012 | 03:23 PM
BigT2's Avatar
BigT2
On the 96 there is a fuse holder on the driver's side by the front side marker light. It allows you to take the fuse out so you don't run the battery down with the hood open. Check it to make sure there is a fuse in it.
T
Old Jun 29, 2012 | 04:12 PM
Sworn's Avatar
Sworn
St. Jude Donor '12
Yes, save battery
That's what I thought, thanks!
Old Jun 11, 2021 | 11:02 PM
postcar's Avatar
postcar
mine on my 93 are not working as well, took lens off, took test light from neg side of battery and touched terminals on both lights , hot on both sides of bulb and mercury switch, so i suspect a ground issue, where should i look for ground? thks
Old Jun 12, 2021 | 08:01 PM
hcbph's Avatar
hcbph
When I bought my 86, the mechanic left the hood up over a weekend resulting in a full dead battery. I don't remember exactly where I got it but might have been Ecklers, I found a wiring harness with a switch in it that's a plug-and-play installation. You unplug the 2 wires from the existing lights and this plugs in. There are weatherpack connectors on it so no modifications were needed. One connector plugs into the power wire on one side, there's a plug that seals off the other power connector. Next are 2 connectors that plug into the existing wiring harnesses to the lights on the hood. There's a weather tight switch in it that turns power on and off to the lights assuming the hood is up. The most difficult part was getting the wiring around the radiator as the light connectors are one on each side of the radiator. It's worked out great, I leave the switch off unless the lights are needed so whether the hood is up or down there are no lights until desired.
To under hood lights
