Final word on speedo correction???
Old Jul 2, 2012 | 06:30 PM
mfi's Avatar
mfi
Default Final word on speedo correction???
Going to swap out my 2.59 rear for a 3.07..1992 auto..so:
I've read everything here about correcting the speedometer and it gets a bit confusing.
What exactly will I need?
Old Jul 2, 2012 | 07:47 PM
ch@0s's Avatar
ch@0s
A green gear.. that was all it took to do my 91. I still have the gear if you need it. I rotated my VSS IIRC 180 degrees. 92 still have the 700R?
Old Jul 2, 2012 | 09:27 PM
mfi's Avatar
mfi
yes 700R...
Old Jul 2, 2012 | 09:31 PM
ch@0s's Avatar
ch@0s
yes 700R...
Do you want the gear? if so PM me.
Old Jul 2, 2012 | 09:35 PM
mfi's Avatar
mfi
thats all it will take?? That would be great..Don't have to do anything with the one inside the trans..some of the reading I have done here points to a more complicated solution..
Old Jul 2, 2012 | 10:16 PM
ch@0s's Avatar
ch@0s
As far as I know no. I put the new gear in rotated the VSS and drove off.
Old Jul 3, 2012 | 02:29 AM
Cliff Harris's Avatar
Cliff Harris
There are two VSS units. One has the shaft that the gear mounts on offset to take a bigger gear with more teeth. If your shaft is centered then you don't need to rotate the VSS. I'm pretty sure the 2.59/3.07 VSS has the shaft centered.
The clamp that holds the VSS in the trans fits in ridges in the VSS and it is meant to go in only one way. I knew I had a picture, but I guess I didn't upload it before, but here it is (3.07 with green gear -- red gear on output shaft):
Old Jul 3, 2012 | 02:48 AM
rodj's Avatar
rodj
Originally Posted by Cliff Harris
There are two VSS units. I'm pretty sure the 2.59/3.07 VSS has the shaft centered.
VSS required relates to the speedo driven gear
VSS GM # 25007224 did driven gears with 35 - 39 teeth
VSS GM # 25007308 did driven gears with 40- 45 teeth
Old Jul 3, 2012 | 04:10 AM
toptechx6's Avatar
toptechx6
Changing the drive gear on the transmission tailshaft is only necessary for rear axle ratios lower than 3.07 such as 3.45,3.56, 3.73.
Old Jul 3, 2012 | 08:46 AM
mfi's Avatar
mfi
OK, guess I'll find out when we go to do it..
To Final word on speedo correction???
