keep getting bad preformance
Old Jul 10, 2012 | 09:56 AM
hitmanpty's Avatar
hitmanpty
Originally Posted by AGENT 86
Have you checked for any stored codes in ECM, yet ?
Is the TPS idle voltage set ?
No i Have not i was going to doit last night but i was to taire to doit. I did check the tps once. I dont remember the reading but i do remember there was a reading fluctuación went i move the gas
Old Jul 10, 2012 | 04:26 PM
hitmanpty's Avatar
hitmanpty
I was reading my other post about this problem.. every thing start. when I chenge the fuel injectors. at firs the car dont even start.
so I desided to doit all over again., this time put some sylicone on gasquet and put the retainers clips on the fuel injectors.
very importand. is I only have 6 clips on the injectors I mising 2
after I arrenge the fuel injectors and put everything back together.the car run again.
I will check the timing and stuff again. but after reading the old post I think I sure get the 2 injectors clips I need. and check the fuel preasure again.
may be Iam getting some kind of problem on the fuel injectors proper seal
Old Jul 12, 2012 | 11:56 PM
hitmanpty's Avatar
hitmanpty
today I was doingsometest on the car. like se if I have fuelpreasure. checking for injectors wires pulse. the car was runing. bad but runing. and out of no thing the car just stop. this time did not start again.now I have no start condition.
TIME TO GETAMECANIC
