Help with codes
Old Jul 12, 2012 | 09:22 AM
jadiff's Avatar
jadiff
Default Help with codes
I have a 95 that gets an occasional service soon light. It generally happens after the car kind of lurches. I haven't really been able to nail it down to when it happens, but I think it is between deceleration and re-accelerating at slower speeds. It happens so fast, it takes me by surprise. Anyway, the light comes on for a few miles and then turns off after the lurch. Yesterday, while coming to work, the light was on for the entire drive (highway driving and I did not notice a lurch), so I used the paperclip to pull the codes and got an H25 on module 1 and an H48 on Module 4. 9 and A were ---.
Diagnoses and remedy ideas? I'm nowhere near a gearhead, but more than willing to turn a wrench. The extent of my knowledge ends at replacing brakes, oil and such, although I did just replace the clutch master and slave cylinder. So, layman's terms would be really helpful.
Thanks-
Old Jul 12, 2012 | 01:20 PM
96GS#007's Avatar
96GS#007
Thanks-
Google works wonders.
DTC 48 - Mass Air Flow (MAF) Sensor Circuit
Check the connection to the MAF sensor
Clean the MAF sensor wires using some contact cleaner. Do NOT touch the wires. The wires accumulate oil over time which leads to poor metering and performance.
Old Jul 12, 2012 | 02:52 PM
pcolt94's Avatar
pcolt94
Also it might be best to get "throttle body and air intake" cleaner it's designed not to do any damage to the MAF and the wire and resistor unit that is suspended.
Never really examined the contents of the throttle cleaner compared to a basic cleaner. But I read enough about it and I would rather be safe on a expensive piece like the MAF sensor.
Old Jul 12, 2012 | 02:57 PM
jadiff's Avatar
jadiff
Thanks to both of you, I will do that. Is the 48 error causing the 25 error? Also, do the lurching problems I described sound like it is related to a potentially dirty MAF?
Thanks again-
Old Jul 12, 2012 | 04:43 PM
96GS#007's Avatar
96GS#007
Thanks again-
The PCM code has nothing to do with the CCM code.
Old Jul 13, 2012 | 01:25 AM
Cliff Harris's Avatar
Cliff Harris
There is a list of the error codes and what they mean here:
http://forums.corvetteforum.com/1576116036-post35.html
Old Jul 13, 2012 | 01:40 AM
Silver96ce's Avatar
Silver96ce
H25 on Module 1 is courtesy lamp coil circuit open or shorted to ground. It is a CCM (Central control module) code and has nothing to do H48 in module 4, a PCM (Powertrain Control Module) code.
H just denotes that it is a history code meaning it is not present at this time - it has occurred in the past but is not presently occuring. C would denote a current fault code.
To Help with codes
