Another LT1 Stalling
Old Aug 14, 2012 | 10:24 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Score, found out my mechanic just so happens to have a GM unit he uses as a test module that he'll loan to me. Crossing my fingers she fires right up tonight!
Old Aug 14, 2012 | 10:24 PM
shakedown067
No go with the new GM ICM. Get to dig into the wiring this weekend, then on to the opti. Any chance the wiring to the oil pressure sending unit would have wires along with it that would cause the car not to fire? My sending unit has been replaced twice but is still wacky. I've been told it's very difficult to get to that wiring harness though.
Old Aug 24, 2012 | 09:56 PM
chrldo's Avatar
chrldo
have you checked the EGR?
Old Aug 24, 2012 | 10:29 PM
96GS#007's Avatar
96GS#007
Do you have a scan tool or data logging software? I'm wondering if the PCM has a bad solder joint or two in it. Heat and vibration can cause the intermittent symptoms. On a scan tool, you'd typically see some or all of the PCM data drop out.
I would verify all the grounds are tight and I would verify the battery cables are tight. Also be sure to check the battery ground that runs from the negative terminal to the frame and check the battery leads at the starter. I had a car that would do this same thing...intermittently die. Turned out the battery cable at the starter was loose.
Next I would look in the FSM at the wiring associated with the ICM, coil, and the Opti. At least that way you only have a handful of wires to test.
Old Aug 25, 2012 | 03:12 AM
tahoemedic's Avatar
tahoemedic
If possible when it dies, check fuel pressure. Sounds like the fuel pump is on its way out
Old Aug 26, 2012 | 11:18 AM
themadvetter's Avatar
themadvetter
Yep
I played this game last summer....fuel pump fixed it for me.
Old Aug 27, 2012 | 08:55 AM
shakedown067
I've got plenty of fuel pressure, but no spark. I've had zero time to work on it for a couple of weeks, not sure when I'll get back to it. All battery connections are good. Have triple checked. Starter fires fine, so I haven't checked that connection.
Old Aug 27, 2012 | 11:46 AM
themadvetter
Well I'm not a mechanic but I would expect normal fuel pressure when she fires right up. My 96 had similar symptoms and normal fuel pressure at the shop when running, but I never checked it at home when she was dead. She finally quit running and sat for two weeks, engine would crank fine but never fire up. I read on CF to listen for the fuel pump engage but i didn't hear it. Changed the factory original FP and have put in 3500 miles with no issues.
Old Aug 27, 2012 | 12:02 PM
shakedown067
Again, fuel pressure checks out OK. I can also hear the fuel pump just fine. I KNOW I don't have spark, as I've used a spark test light and nothing is getting to the spark plugs. I "think" the coil is firing, but haven't checked it since she's last been out of service. That'll be my next check once it quits raining so much.
Old Aug 27, 2012 | 03:48 PM
shakedown067
I do have a scan tool via my iphone (goPoint). All the data seemed to run smooth when she was running, but I mainly just use it for ready code errors on the vette and my wifes car. My vette mechanic mentioned that too and last time she died, I gave the ECM a nice pop on the top, then the damn vats kicked in. That was fun. Haven't tried it since...may have to when I get home tonight. I think I'd actually rather it be the ECM than the damn opti again...just for the sake it'd be the third stinking one in 8 years. And I've got a vented opti, so it shouldn't do this crap (if it's indeed the opti). But still no codes.
Old Sep 4, 2012 | 11:46 AM
shakedown067
Well, I pulled the wiring harness to the opti this weekend. It's COVERED in oil. Cleaned it off, plugged it back in and it fired right up. What sucks is I just had the seal replaced a year ago. I had a pro do it with the proper tools and used a GM seal. Another local shop I visited recently has had the same issue with a 96. It's on it's fourth seal in just a couple of months. They too are using GM units (although don't know if they've tried anything else since the first couple went). Any other brands that y'all have used for the seal behind the opti??
Old Sep 4, 2012 | 01:34 PM
HammerDown's Avatar
HammerDown
Maybe a bad batch of seals? Normally I would have suspected the mechanic rolled the seal edge by not using the right tool putting it in, but you said he used the proper tool.
Sure it's coming from that seal and not something above it?
Old Sep 4, 2012 | 01:48 PM
  #33
shakedown067
Not 100%, but I had everything on the front of the engine replaced at the same time. So it's still a new seal that's let loose. I don't seem to have much oil anywhere else, but if I have to order new seals rather than my mechanic, I'll get them both. Most likely he'll tear into it and then order what needs to be replaced. Just curious on what brands other's have used. Should probably start another thread....
Old Sep 4, 2012 | 07:02 PM
  #34
93Rubie's Avatar
93Rubie
Ask him if he is putting Trans Gel or Trans Assy. Lube on the inside of the seal where the garder spring is. I ALWAYS do this as it helps to keep it in place when installing.
Also, if things are worn, the shaft could be walking around and taking out the seals.
Old Sep 5, 2012 | 08:27 AM
  #35
shakedown067
Man, don't be telling me things like that! Would be about my luck with this car though.
Old Sep 5, 2012 | 04:36 PM
  #36
HammerDown's Avatar
HammerDown
In another thread I had recently about my new AC Delco China water pump, someone advised me to check for wobble (runout) on the splined drive shaft of the pump. If that thing is not straight, it can make the drive shaft in the timing cover wobble around too, which will wear out the seal quickly. This guy had a persistent oil leak from the timing cover that they just could not fix, until they found the runout present in the water pump drive shaft.
Food for thought.
Old Sep 5, 2012 | 05:29 PM
  #37
shakedown067
Well, that would actually be good news. But would the oil leak into the opti? The harness going into the opti at the bottom was covered in oil. Wiped it off, and it fired right up...or was that just from me plugging and unplugging the opti. I'm worried I've still got more than one issue going on.
To Another LT1 Stalling
Old Sep 5, 2012 | 10:15 PM
  #38
93Rubie's Avatar
93Rubie
You may want to check pin tension/fit on those terminals and pins. Over time they can loosen up from vibration/age/heat. They make tools for his or just use a small eye glass screw driver and tighten them up a bit. Use your own judgement to fit them.
Old Sep 5, 2012 | 11:45 PM
  #39
HammerDown's Avatar
HammerDown
Well, the water pump drive seal is right above that opti connector.
Old Sep 12, 2012 | 03:36 PM
  #40
shakedown067
So got brave and drove it to work yesterday as she's been firing up at will each morning and evening the past few days. Yep, it's now stranded at work. Drove great to work. Didn't go out for lunch, and when I went to go home...no start. Will be kinda nice having it out of the driveway for a while though. Maybe I'll get to tend to it in October.
