heater hose routing???
Old May 27, 2002 | 11:36 PM
396 Roadster's Avatar
396 Roadster
Default heater hose routing???
Does anyone have any pics of where the heater hoses route on a TPI car? There is a top hose that Y's, and a lower hose. What do they connect to? Which one goes to the water pump?
Old May 28, 2002 | 05:26 PM
pablocruise's Avatar
pablocruise
Default Re: heater hose routing??? (396 Roadster)
the one that "T's" off at the air conditioner bracket goes to a metal line that is shaped around the oil pan and goes to the oil cooler to which the oil filter is screwed onto. You could just do a bypass and run the other hose straight into the intake manifold fitting on front of engine by the thermostat area.
Old May 29, 2002 | 04:56 AM
396 Roadster
Default Re: heater hose routing??? (89 Paul in Cal)
I took a look at another car today, and I think I'm going to replace both molded hoses with universal straight hose to get rid of the Y. I have cut my IAC housing off so I'm just routing it directly to the intake manifold. I also got rid of my oil cooler.
Old May 29, 2002 | 05:06 AM
pablocruise
not a bad idea. I've seen people around here refer to the oil cooler as an oil heater! :lol: :eek:
To heater hose routing???
