88 4+3 issues
Old Jul 17, 2012 | 08:57 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Default 88 4+3 issues
Hi guys, my 4+3 has a couple of issues I would like to tackle. The first one is overdrive related. When coming out of OD it clunks like a hard shift. The FSM is saying it may be a stuck TV valve. Anybody have any luck unsticking one of these? The second issue is getting it into gear after a stop. Sometimes I have to let out the clutch a little and move the gears a bit to get it into first. The is the second C4 I have had this problem with. Is this a common failure? Syncro's? My FSM didn't have anything on this one. Anyway, any help would be appreciated.
Old Jul 17, 2012 | 09:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is no TV cable, auto only.
I use the clutch when manually going in and out of OD, easier on all the old parts and doesn't give you that clunk sound.
Old Jul 17, 2012 | 11:14 AM
Bob1985z51's Avatar
Bob1985z51
On the 4+3 od unit theirs a cable from the od to the throttle linkage and I think that's the tv cable.
Old Jul 17, 2012 | 12:34 PM
AGENT 86's Avatar
AGENT 86
Not on the OP's 88
Old Jul 18, 2012 | 08:50 AM
87FIREREDRAGTOP
There definitly is no TV cable. The FSM is showing a TV valve in the OD valve body and sugests that the hard down shift is a stuck valve. I was going to pull the vlave body off and see if I could free it up. Just wondering if any one else has run into this. My FSM is from an 87, but I believe the same would apply to the 88(I hope)...
To 88 4+3 issues
