ac/heater blower problem
Old Jul 18, 2012 | 06:55 PM
benenuf's Avatar
benenuf
Cruising
Default ac/heater blower problem
my heater blower motor does not work on all speeds barely blows on hi and does not blow on low or medium any suggestion on 85 c4
Old Jul 18, 2012 | 07:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Good chance it's the blower resistors on top of evap housing.
Diagnostics from my 86 FSM
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Old Jul 19, 2012 | 03:40 AM
Cliff Harris's Avatar
Cliff Harris
I believe there's a relay that bypasses all the resistors when you go to the HIGH fan setting. It sounds like that circuit isn't working the way it ought to.
I had a '78 Corvette that had the symptoms you describe. One of the resistors was broken.
Old Jul 19, 2012 | 09:27 AM
T. Wayne Nelson's Avatar
T. Wayne Nelson
I could check my FSM but if my memory is still with me i don't believe there are any resistor on high. The way to check the fan on high is to use a jumper wire from the battery and if it does not blow hard, then it is likely the fan motor...
To ac/heater blower problem
