I decided to open a new thread about my no spark problem.
here what I have done
almost rebuild the distributor. new ignition coil, new pickup coil, new cap and rotor. did not change the module, because i can not get it here in my country.
I change the ecm. becouase the other one was afecting my injectors. but the one I get is an used one . not sure if this one is good. one thing I have to do before instal the new ecm was to change a capacitor, that was broken inside the ecm. I did use the one I had in the old one. so that let me to think. this last ecm is no good.
If I disconect the 4 pin connector on distributor I get a spark but if I re conecte , them i have no spark condition.
my question.
do no spark conditon have something to do with the ecm???????
I read some where that the ecm only take information from distributor to set timing or something.. dont really know
The 4-pin connector on the distributor goes to the ECM. The ECM controls the timing of the spark. Disconnecting the connector will put the ICM in "bypass" mode (the same as opening the EST connector). Your timing will be fixed at the base advance (6 degrees, or whatever you set it to).
Sounds like the "new" ECM has a problem. Did you put the MEMCAL from the old ECM in the new ECM?
There is a troubleshooting section in the FSM that tells you what to do if you have no SES light. Page 6E3-A-18.
ok bit i think the problema is. that the circuit is ola and in bar shape i had it out once and justo by looking at the circuit film yo can twll is bad .
i think i had a pintura some where Will try to post later
I just got the new ecm today . I just plug in and see if I have spark now. IF NOTHING them I know I have to look somewhere alse. since this ecm is tested and warranti
ok I just instal the new ecm.
now i have spark. ok
I have 40 psi fuel preasure and holding
Injectors wires have pulse when crank
so I have fuel, i have spark and i have good air. dont see no vacum leaks.since i fix them all.
the only think i can think of. is timing.
i did remove the distributor compleately.
but I did the following.
first piston all the way up. at TDC. i check with a metal wire the position of the piston. also in the way up I use my finger to feel the preasure on cilinder number 1. coming up. them use the harmonic to move have ench to put on tdc mark.
alight the rotor to point to number one cilinder and instal the new dist. pole cap, number one alight with rotor.
treaple check the fireing order on spark plug wires.
I get no start situation. not even an explotion.
one think call my atention. the spark I notes kind of weak spark. dont have a point of referance. but look to me like the spark is weak.
but remeber I have new pickup coil, new ignition coil cap and rotor
can someone point me to the right direction. like to have this solve this week end. I know I have to be close.
